Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-09-2004, 06:49 PM
Huffa Huffa is offline
Quiz ? Know what to do?
This is pertaining to a 94 and am sure it goes from at least 90-96...not sure about newer models.
You start your automatic 3.0 V-6, go to put it in gear and the shifter won't move. What is the vehicle telling you and whats the very quick way to fix it for the time being till you get the cheap part?
I really don't know if a manual has the same set up or not?
Old 09-09-2004, 07:24 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Quiz ? Know what to do?
It's telling you to press on the brake
Old 09-09-2004, 07:30 PM
Brian R.'s Avatar
Resident Chemist
ok, you press on the brake and it still doesn't go into gear. Then you pry up the window by the shifter with a screwdriver and you push down through the hole and manually actuate the shift lock control switch.
Old 09-09-2004, 08:25 PM
You got it!
I found if I blow a fuse to the brake-tailights (towing trailer sometimes) it will do it. Good safety feature I think. That way you know you have no rear lights.
Old 09-09-2004, 09:05 PM
Brian R.'s Avatar
Resident Chemist
Interesting
