Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-09-2004, 05:27 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Largest tires on stock suspension?
Im wondering what are the largert tires i could get on my ram. There is alot of wheel well room and i wanna get some larger tires to fill the gap and make it look a little meaner.
all stats on the truck are in my sig.
Pictures of the Truck
Old 09-10-2004, 04:03 PM
Gregor Gregor is offline
Not sure the answer to your question, but will offer some advice which you may already be aware of. A significant change in tire size will 1) make your speedo very inaccurate 2) reduce the power your truck has and 3) reduce your gas mileage. This goes along with the other obvious issues of bigger tires cost more, wider tires often don't wear as even and are very noisy. If you still feel you want to have that look, I would invest in a change in your gear reduction so that you maintain the stock ratio.
Old 09-10-2004, 11:19 PM
TurboSW's Avatar
TurboSW TurboSW is offline
Re: Largest tires on stock suspension?
Man, you just took all the fun out of it.
Old 09-18-2004, 08:59 PM
moparboy99 moparboy99 is offline
Send a message via AIM to moparboy99
I had 305/70r16 on my truck and they looked great, but when you turned sharp they rubbed alittle but you can adjust your stops. as far as the speedo you can get that recalibraed by a delership or if you have the scanner like i do you can do it your self
Old 09-18-2004, 10:53 PM
milkman1's Avatar
milkman1 milkman1 is offline
Most tire company's will mount up a tire and put it on your truck to see if it will clear before you buy. Atleast the ones here do. That way your not out any money for stuff that won't fit. Some Dodge's will accept a 35" tall tire with no mods, but most the limit is 33's
