Old 09-09-2004, 12:49 PM
Qbart Qbart is offline
Question 99 Ford Taurus - Overheating
Hello all,
I have a 99 Ford Taurus SE. My problem first started when I noticed what smelled like anti-freeze coming out of the air conditioning vents. I stopped using the air. Now whenever I am stopped the engine starts to overheat, when I start to move again the temperature goes back down. Could this be as simple as a thermostat?
Any help would be greatly appreciated.
Thanks
Q
Old 09-09-2004, 01:22 PM
Dave P Dave P is offline
Could be the thermostat. Could be the coolant temp sensor. Could be fan clutch. Could be fan relay. Could be the Water pump. Could be head gasket. Does your Radiator cooling fan run when the car is hot? Do you have coolant in the oil (watery)? Do you leak any coolant? What ever you do, try not to let it overheat, it can cause expensive damage.
My wild guess, check your fan/fan relay.
Old 09-09-2004, 02:12 PM
Thanks for the tips Dave. I'm at work now so I'll have to check it out later. How do you check the Fan/Fan relay?
Thanks
Q
Old 09-09-2004, 03:17 PM
Just make sure the fan kicks in.
Old 09-10-2004, 12:49 AM
2001BlackSES 2001BlackSES is offline
Re: 99 Ford Taurus - Overheating
Still haven't answered the smell of anti-freeze coming from the air vents when A/C is on. What in the world is going on there, anybody? Absolutely related to your overheating problem. You have a leak somewhere, check your coolant level and check it often. I know when a heater core is bad and leaking you'll get that smell when you run the heater, but I don't have a clue about the A/C system.
Old 09-10-2004, 09:41 AM
OK,
I know I'm not the smartest person when it comes to cars but after looking at my taurus again, how do you check the Radiator Coolant level?
All I see is the overflow reservoir, the radiator is buried in the front and I don't see anywhere where there is an actual radiator cap.
I have seen the fans and again I'm at work and I will check those out later.
Ok this is what I know at this point.
I checked the oil and besides being dirty it looked OK.
I thought I was told by a mechanic friend years ago that if you loosen the radiator cap that might help some overheating problems, so I loosened the only cap I could find which was on the coolant reservoir. The car started to get hot after driving only a couple of miles and wouldn't go down until I stopped and tightened the cap back up.
I also noticed that when I'm idling and the car starts to get hot, if I put it in Park it goes down.
So, I will check the fans later today. When should they come on?
Also how do you check the coolant level? I know that sounds dumb, but I am really mechanically declined!
Last thing is I am going to take it to a mechanic next week, I will post back then to let you all know what the final diagnosis is, I really hope its not a head gasket!
Thanks for all your help!
Q
Old 09-10-2004, 10:49 AM
86TATpi 86TATpi is offline
The pressure cap is on the overflow tank. On those it's called a surge tank because of the cap location. You can check the level of coolant by the lines on the side of the surge tank or taking the cap off. The heater core and the air conditioning evaporator share the same housing. When you turn the heat on does it smell like coolant in the car? It could be leaking there. When you do turn on the ac, do the fans kick on? It could be a number of things still, if you can check those and let us know what you find.
Old 09-10-2004, 10:55 AM
The purpose of the pressure cap is to maintain specific pressure in the cooling system. For every pound of pressure on the coolant, you raise the boiling point about 3 degrees. So a 15 psi cap raises the boiling point by 45 degrees. That increases your protection. If the relief valve isn't working then it would continue to build pressure and eventually rupture something in the cooling system. If you were to loosen the cap you take away that added boiling protection, causing the car to overheat. Low coolant can be a big problem, so it could be a leak (even a small one) in the heater core or somewhere else on the car. Do you notice any coolant on the ground if it sits for a while? Or anything in the passenger compartment? Another good hint was to make sure that the fan(s) are kicking in when the car reaches temp.
Old 09-10-2004, 11:52 AM
Just so you know there is no radiator cap on the radiator itself. The coolant system is filled through that clear plastic resevior tank located at the right side of the engine compartment next to the alternator. The coolant system in your car requires 16 psi of pressure to be able to operate properly. Thats why it overheated without the cap installed. Well that and I have a real good feeling it's low on coolant.
Old 09-10-2004, 12:13 PM
Willyum Willyum is offline
Should consider a dirty cooling system. What kind of water have you been putting in it? A high mineral content water will form constrictions in the radiator that can't be flushed out. Is like cholesterol in your blood stream.
Old 09-10-2004, 12:22 PM
Good point, it is a 99' and the overall condition of the coolant system is unknown. Have you kept up on the coolant system flushes every three years or 36,000 miles? Still there must be a leak somewhere for an odor of anti-freeze to be coming out of the heater/air-conditioning vents. Let us not forget that. Let me ask you to do this and let us all know how it turns out. Turn on your heater and flip it to defrost. Tell us if your window fogs up. If the heater core is bad/leaking it will fog up the windwhield in a matter of moments and smell like anti-freeze. Even a small leak will do this.
Old 09-10-2004, 01:31 PM
Alright this is what I did, at lunch I went out and looked in the surge tank and its pretty much empty! I then started the car, put the heater on defrost and let it run for awhile, no heat came out and the windows didn't fog up. Then I checked the fans and both of them are working.
I drove the car to the auto parts store to buy some antifreeze, on the way I put the heat on again and it was working, I had all the windows rolled up and still no fog on the windshield. Then the heat stopped putting out hot air, I did not smell any antifreeze. I turned off the heat and continued to the store. At one red light it started to get hot but nothing over 3/4 of the way up in the white box area on the gage.
Now when I came back and was in the parking lot and parked I noticed the heat gage rising again, I hit the gas a little and it quickly jumped back down.
Now I'm going to put in the antifreeze after the car cools down for a few hours. Again this will sound dumb but just to make sure I add it with the car running, right?
How do you know when you put enough in?
Thanks for everyones help on this!
Q
Old 09-10-2004, 01:34 PM
As far as changing the coolant, I've only owned the car for the last 20,000 miles or so, it has 109,000 miles on it now.
Old 09-10-2004, 01:47 PM
Were the radiator fans running?
Also, it may not be leaking because it is way empty! Get some fluid in there ASAP or you are going to do some real damage. I'm not sure where you live but I would just dump in a half gallon of anti-freeze for ever 1/2 gallon of water, keep adding to the reservoir and as the engine warms up it will get sucked into the radiator. keep adding until you are at the "full hot" level on the reservoir.
For the time being if you must just put water in it but don't drive it until it is full. Check to make sure your fans kick in.
You can go to most service stations and have the coolant system pressure tested for leaks for only a few bucks.
Good luck!
Old 09-10-2004, 01:54 PM
Thanks Dave, and Yes, both fans on the radiator are working.
