Old 09-09-2004, 10:59 AM
jberry3 jberry3 is offline
Tamiya Paint
Now I finally sorted the putty work out on my Tamiya R34 skyline gtr fitting the SAS n style kit i decided to paint it. I run out of white primer but i decided that the yellow tamiya paint should cover it in a few coats (Wrong) It didnt and also i cant believe how messy it sprayed and it was a new can. I think i will stick to auto paint in future as it is cheaper and more in a can. So the main question is can i get castrol super clean in th UK?
Old 09-09-2004, 11:45 AM
freakray freakray is offline
AF Modelrater
Re: Tamiya Paint
It doesn't matter whether you can get CSC in the UK or not, CSC doesn't remove Tamiya paint unless you leave it for weeks.
Get some regular brake fluid and set the body in that to remove the paint.
BTW, you do realise removing paint will probably remove putty too?
AF User Guidelines
Old 09-09-2004, 12:00 PM
Vric's Avatar
Vric Vric is offline
Re: Tamiya Paint
Clear color (yellow, Red, White, pearl) never cover fully. You need a nice even primer surface for those color and doing many light coat.
Not want to be hard, but a litle search before painting would gave you the answer before doing a "messy" paintjob..
anyway we all need to learn the hard way.
But don't juge Tamiya paint of a "messy" paint job that it was you own fault. We all do mistake
As for the removing paint, I would simply go with a sand paper and recover with primer. If you use CRC or other stuff, the putty will be gone
