Go Back   Automotive Forums Car Chat > Honda > Integra
Old 09-09-2004, 09:59 AM
Diablos2431 Diablos2431 is offline
Send a message via AIM to Diablos2431 Send a message via MSN to Diablos2431 Send a message via Yahoo to Diablos2431
Need New Motor
Hey everyone, I have an 89 Integra D16A1 m/t. I am trying to find a B16A1 for a swap and i'm trying to spend as little money as possible. If anyone knows where I can get a cheap B16A1 from any help would be greatly appreciated. If not a B16A1 a D16A1. Thanx again.
TJ
Old 09-09-2004, 11:48 AM
Rating's Avatar
Rating Rating is offline
Send a message via AIM to Rating
Re: Need New Motor
Cant help you there, but I'm selling a B18C1 for $1,500. I live in S.C. if your interested.
Im not proud of my car because its fast, Im proud of it be cause I built it that way.
Old 09-09-2004, 12:19 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Need New Motor
https://passwordjdm.com/index.php?pa...id=engineswaps
$1399, cheapest full swap I've seen around.
Old 09-09-2004, 02:35 PM
Re: Need New Motor
Rating, wat condition is ur B18C1 in? How many miles are on it? And are you selling just the engine or the whole package? The last thing I have to ask is would it bolt up with my car or would I have to make it fit, do you know? Thanks for the info. Also thanx civicspoon for the site.
Old 09-10-2004, 03:25 AM
Rating's Avatar
Re: Need New Motor
The B18C1 is in excellent running condition. Has around 110k miles. Its just the motor im selling, no tranny, no ecu, no mounts. If your trying to find a b16a motor to swap in, you would have to do the same process with the B18C1.
What I am selling is a B18C1 Motor for $1,500.
Items included for free are:
I do have reciepts of purchase if needed.
These are not pre installed.
Brand New Poly and Aluminum Motor Mounts $200 Value
OBX Cam Gears $100 Value
These were removed during the motor pulling process.
ACT Stage 2 Turbo Clutch $460 Value
OEM Intake Manafold
OEM Flywheel
OEM Header
OEM Oil Pan
OEM Distributor
OEM Spark Plug Wires
OEM Spark Plug Cover
And anything extra I can find laying around here for that motor.
Old 09-10-2004, 01:45 PM
00EclipseGTsport's Avatar
00EclipseGTsport 00EclipseGTsport is offline
Send a message via MSN to 00EclipseGTsport
Re: Need New Motor
Get a use LS motor and 5-Speed trans. Swap in a light flywheel, and race clutch. Drop the engine in. Install a cylinder brace, block girdle and quality head gasket. Then slap on a Drag turbo kit and be done with it.
Should the LS engine go, you can pick another up cheap and swap the turbo on it.
~ Steve
00 Eclipse GT - 00 Montero XLS 4x4 - 96 Integra LS
99 Kawasaki ZRX 1100 - 81 Suzuki 450 cafe' racer - 75 Kawasaki KX 250 - 74 Suzuki YZ 125
69 Ford Galaxie XL Conv. - 69 Ford LTD 2-door Formal Top - 67 Ford Galaxie 500 Conv.
CHECK OUT MY RIDES BY CLICKING HERE
