1999 infinity stereo / power drain
when the infinity stereo amplifier wiring harness is plugged into the amplifier, the battery goes dead overnight. therefore, i believe the problem is in the amp. however, it could be in the radio.
3 questions 1) the amp is easy to remove, but how do i remove the dash, in order that i might remove the radio for having it checked-out? 2) any suggestions on a repair facility for the amp/radio. 3) anyone out there have a working system for sale in the event mine is not repairable??? in advance, thanks for your help, richard |
I have the infinity sound system as well, however I replaced the facotry radio with an aftermarket radio. In order to remove the radio, simple stick a putty knife or flat head screw driver right underneath the A/C vents and all the way around. It is held in place by spring clips and can easily be put back into place. I also have the factory radio which I would possibly we willing to sell to you. It is in prime condition.
Re: 1999 infinity stereo / power drain
What year, etc is your Jeep? I have a 98 GC and the amp is under the back seat, simple removal. flip the seat cushion up and there it is. yours might be different...
check the wiring harness for the amp that goes under the seats u prolly have a HOT WIRE bare, causing it to ground out soewhere which is draining ur battery.
