Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-09-2004, 03:57 AM
xs081 xs081 is offline
Good Drift Springs
Since we all know what everyone has to say about what coilovers they have and like for drifting, i want to know if there is a good set of springs for drifting. Maybe a combination of spring rates blah blah blah. Fill me in please.
Old 09-09-2004, 09:06 AM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
hmmmmmmmm,
all the aftermarket springs im aware of are not setup to great for drifting. They have higher spring rates up front, and usually weak spring rates compared to some coilovers.
Id go with the stiffest possible springs, linear would be best, and a nice expensive quality strut, ATLEAST kyb agx or comparable, and if you are going that route I would try to buy some aftermarket swaybars sooner. This will atleast make your car have more grip and less body roll... it will help when drifting, it shouldn't be as good as a drift type coilover, but it should be better then stock for drifting.
Old 09-09-2004, 07:13 PM
Re: Good Drift Springs
ok, what about the ground controll coilovers? Is the spring rate high enfough? The reason i ask is because i get get them from a friend for prety cheap. I would still like to hear more opinions on the springs. Thanks.
Old 09-09-2004, 07:24 PM
I just found these white line springs. heres the spring rates. Spring Rates: Front 157 lbs/in (linear) & Rear 132-205 lbs/in (progressive) arent springs normaly measured in Kg?
