Old 09-08-2004, 11:22 PM
Gateway's Avatar
Gateway Gateway is offline
At what psi can I use safely with 13g turbos?
I found out 13g turbos are alot cheaper than I expected, so I will probably get some.
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 09-09-2004, 12:06 AM
GritMaster GritMaster is offline
Re:
Pick up a propane injection kit (about 300 bucks) if you've got the spare money, and you wont have to worry about it.
But I think not positive, someone else I'm sure will fill you in that up to like 14psi is safe? Dunno, used to... but I forgot... I've only been lookin t 15g's
RIP Andy "Hypsi87" Filson... We'll miss ya mate
Originally Posted by nissanstreetz
For about 700 dollars you can have about 80 horespower at the wheels and about 70 torque.
Old 09-09-2004, 10:59 AM
Jag1718 Jag1718 is offline
I'm pretty sure they hold up to 17 psi TO redline. Do NOT go over 21 psi with those 13gs because it's not gonna last. Sounds like a good amount of horsepower gain.
Old 09-09-2004, 11:29 AM
Igovert500's Avatar
blue + red light magnet
Re: At what psi can I use safely with 13g turbos?
Well you wont be able to touch anything liek 17 or 21 psi or even go past stock levels without larger injectors, an upgraded fuel pump, and probably an A/F controller. At 14psi on the stock turbos, the fuel injectors are already running way over thier efficiency range. You will get fuel cut...and it will be painful for you and your engine...boost safely...with the right supporting mods.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 09-09-2004, 06:04 PM
Gateway's Avatar
so with 14psi on stock turbos, what should I get to safely run my turbos?
'92 3000GT VR4
Current Mods:
K&N FIPK
Rebuilt tranny
Free Boost Mod
Old 09-09-2004, 10:23 PM
alan92rttt's Avatar
alan92rttt alan92rttt is offline
How much boost can you push? Depends on your suporting mods.
I maxed the stock fuel system out on only 12psi of boost.
Alan Michigan 3S
The Toy 1992 Dodge Stealth RT/TT 13.3 @ 102mph
The Daily Driver 1998 3000GT SL
www.3sgto.org - The New home for 3S Enthusiasts
Old 09-09-2004, 11:46 PM
I figured he'd know that it would be on stock parts...
Old 09-10-2004, 12:45 AM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
What exactally are the limiting factors for boosting, what parts need to be upgraded and at what psi should one upgrade them? What is the staged upgrades for suporting boost?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 09-10-2004, 09:56 AM
Igovert500's Avatar
http://www.3si.org/pages/stagedpower.html
this is a good staged mod site, although, I don't agree with upgrading the exhaust so early...just the downpipe.
Specifically though, your injectors, fuel pump, and an Air/Fuel controller are needed if you plan on boosting past 14.5psi or if you plan on getting upgraded turbos. Also, if you boost past there, you will probably need an aftermarket y-pipe, as the stock plastic POS will sometimes blow off around 15psi.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 09-10-2004, 12:08 PM
Thourun's Avatar
How much are new injectors, pump, and A/F controller?
1995 3000GT VR-4
