Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 09-08-2004, 10:07 PM
importcrazy421 importcrazy421 is offline
need some help guys
hey guys my car has a rough idle and it stalls after the 3g warm up in the cold.
But just recently every once in a while it will drop 200-300 rpm with a bearing scretchy noise coming from the ac compressor. It sounds a little scretchy most of the time from the compressor assembly, and by the looks of things a belt was torn up at some point because there is a lot of tar sprey on the radiator fan and that left side (although this could be why he got that new engine in the first place, and used the same fan). Any help will be much appreciated.
P.S. do you think this could be why it has the rough idle problem cause it doesnt seem to have any vacuum leaks.
Thanks.
[IMG][/IMG]
My 89 turbo 2
Old 09-08-2004, 10:25 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
Re: need some help guys
not sure man, my car idles at like 300-500 most of the time lately. it does it when its cold or hot. then sometimes it is really jumpy when I'm sitting idle and then it dies. I haven't really looked at it too much yet so I have no clue whats up, but maybe we have the same problem?
anyways hopefully someone can help both of us lol
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 09-08-2004, 10:34 PM
And yours is NA too right. Ya check your ac compressor and listen for noises, especially when you turn it on and off. If I turn my ac on its noisy but it idles steady so im clueless.
[IMG][/IMG]
My 89 turbo 2
Old 09-08-2004, 11:33 PM
ShortyDTP's Avatar
ShortyDTP ShortyDTP is offline
Send a message via AIM to ShortyDTP Send a message via MSN to ShortyDTP
my S4 stared idle at 1,500 all day today???
out of no where ........
HOLESHOT PERFORMANCE
91 Laser Rs 471 whp at 22psi pump scm-6152e
98 Eclipse GST 11.4 @ 121mph Stock T25/nitrous
Jose Mendoza
Old 09-09-2004, 12:08 AM
89tracerman's Avatar
89tracerman 89tracerman is offline
my idle was at 700 and i decided to raise it to 1000 rpm's is that bad? and yes my car is fixed again thanks to a mexican mechanic i found on a mexican magazine here in Phoenix AZ
Old 09-10-2004, 03:44 PM
ya the specified idle is 750. Not that is will hurt it but will waste more gas. And if it is an automatic then it might change shifting and shift quality a bit.
[IMG][/IMG]
My 89 turbo 2
Old 09-10-2004, 05:40 PM
FCsilvia's Avatar
FCsilvia FCsilvia is offline
check your TPS. S5 tps tend to fail after 100k miles.
check belts.
check fan clutch.
check throttle cable.
adjust CAS.
-1987 Mazda FC3S TII - dynoed 316rwhp 06.28.04
S5/S6 SP motor w/ HKA T04R @ 14psi
CP Racing 4point Roll Bar
Cusco ZeroII Coilovers
SSR Watanbes RS-8 17x8F:17x9R
- 1993 Mazda FD3S Competition Yellow Mica R1
- 1991 Mitsubishi Galant VR4 - daily grind
JDM EVO RS motor w/ EVOIII 16G turbo
Old 09-11-2004, 01:15 AM
Soyo's Avatar
I think I'm just gonna have to take mine to a shop here in town because it kept stalling everytime I slowed to a stop with my foot on the clutch... its pretty frustrating so I'm tired of messing with it...
it wouldn't be the alternator or anything would it? because it seems like the lights and everything dim a bit before it happens, but I guess that could just be that its losing power... who knows
cars piss me off sometimes, but I still love her, even with her ugly body damage haha
