Old 09-08-2004, 09:17 PM
rstrub rstrub is offline
Question Ok, probably stupid question, but...
I recently bought a 1984 S10 Blazer, 4WD, and I need to know if the 4wd can be engaged on the fly (while rolling down the road), or if the vehicle must be stopped. This is the first 4wd I've owned, and I don't want to do any damage before I get to try it out in the snow
Also, I know I need to replace the clutch; right now the clutch pedel seems quite high; will a new clutch correct this problem? Thanks for any help...
RAS
Old 09-08-2004, 09:34 PM
importsdosuck88 importsdosuck88 is offline
Send a message via AIM to importsdosuck88 Send a message via Yahoo to importsdosuck88
Re: Ok, probably stupid question, but...
you can shift into 4wd high on the go but you have to be stoped with it in nutruel or park to get it into 4wd low and I don't know bout the clutch
I like cheese
Old 09-08-2004, 11:02 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
RAS
Do you have to go out and lock the hubs?
If not, you can go from 2wd to 4wd on the fly.
4LO requires a stop and changed in neutral.
Old 09-17-2004, 02:00 PM
annguyen1981 annguyen1981 is offline
Send a message via AIM to annguyen1981
In order to change from 2WD to 4WD high, you have to be going under a certain speed... This is a safety feature... You can definitely try and switch at a high speed (such as 85 mph), but it won't engage until you slow down (unless there is something wrong with the sensor
