Old 09-08-2004, 08:56 PM
Knight2040's Avatar
Knight2040 Knight2040 is offline
Send a message via AIM to Knight2040
Crap, stripped nut
well my stillen downpipe came in and i managed to get every bolt off except the two nuts that bolt the main cat to the rest of the exuast. I rounded the head after resorting to using a hydrolic jack to push a socket wrench up attempting to loosen it. well anyway, what would be the best way to remove the nut? I'v never used a nut splitter, do they work good? i was just gonna attempt to cut it off with my dremel. would this be better? Do i need the thread\bolt thing attached to the cat? or can i just use a normal 19mm nut and bold to bolt my stillen to the rest of the exuast? if thats the case then i'll just drill through it. thanks
1991 Mitsubishi 3000GT VR4 Twin Turbo- Forged Ross Pistons,Forged Crank,Forged and Shotpeened Rods,Stillin DP,K&N FIPK,Greddy Type-RS BOV,Magnacor Wires,Aluminum Y-Pipe,EGR Blocked,All Gutted Cats,Greddy Turbo Timer,Blitz Boost Guage,Autometer A\F Guage,Solid Shift Bushings,Red Top Batt,ACT 6 Puck Clutch,Free Boost Mod,99 Front End Conversion
Old 09-09-2004, 12:27 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
maybe try some rust penetrating solvent if the nut is salvageable. always have some of that handy when working on exhausts...rust builds up very easily under there.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-09-2004, 11:37 AM
Igovert500's Avatar
blue + red light magnet
Re: Crap, stripped nut
I havnt used the nut splitter, but I would think any 19m bolt would work fine. Cut it, if you can get it out/off that way. And for future reference, I agree with Linebckr, get some penetrating oil and drench the bolts prior to doing something like this.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-04-2004, 09:01 PM
MitsuPride3KGT MitsuPride3KGT is offline
use this thing called pentration breaker, it worked for me when my bolt was stripped, and just go and replace the stripped bolt
Old 10-04-2004, 09:05 PM
Knight2040's Avatar
well its been about 2 weeks since i got that bolt off and replaced .....i just went to wallmart, paid 16 bucks for an impact hammer and took it off in 2 minitues lol, impact hammers are handy
