Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-08-2004, 08:50 PM
lightin rod lightin rod is offline
Send a message via MSN to lightin rod
Angry power window not working
i have 94 thunder bird lx and the driver side window quit going up and down the moter runs and it cathchs and moves a little if the window is all the way up the window moter just runs until i let off the button it just started doing it out of no where i tried greasing the track but that did not help. I dont know what else to do and im on kind of tight budget so does anybody have an answer
is it common on tbirds with the 4.6l at around 85,000 miles for anything and everything to start going bad? Thats been my experiance and i curious to know if anybody else had alot of trouble
Old 09-08-2004, 09:15 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: power window not working
There are plastic bushings inside the motor. I believe that is what it sounds like to me. The replacements are only a couple of dollars.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 09-08-2004, 09:34 PM
thanks thunderbird muscle, do u have any ideas on everything going bad i have replaced the computer, plugs and wires, the transmission was replaced shortly before i bought it, nuetral safety switch, and brake light switch. Now my cruise dont work and the scanner says my ect sensor is bad.
Old 09-08-2004, 09:40 PM
oh forgot to ask how does the inner fender come out my power antenna quit working and the antenna end that goes into the radio broke so i have no radio
Old 09-09-2004, 02:13 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Sounds like you need to be a little nicer to your bird... These things are like fine art. Treat them nicely, and they will repay you in the end.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 09-09-2004, 08:06 PM
mpyrol mpyrol is offline
some cars have replaceable masts on electric antennas..... not sure if ford is like that, probably be wise to inquire at dealership. I just bought a mast for a mazda, arent they owned by ford? Radioshack has a solderless antenna end that plugs into the radio.
Cruise control MAY not work with mil light on. temperature sensors are usually cheap and easy to get change. Dont remember where it is on the car but normally stocked by parts places.
Old 09-09-2004, 10:34 PM
Does your horn still work? This will help figure out what might be wrong with your cruise.
Old 09-10-2004, 11:57 PM
yeah my horn still works i probably has sumthin to do with the part of the wiring harness that burnt up, the taillights, nuetral switch, radio, and the clock didnt work. but the cruise wouldnt shut off so we had to run new power wires to everything cause we cant figure out where it burnt up, somebody told dad that there is a switch on the bottom of the steering column that might be bad i dont know, but it annoys me that i have a series of toggle switches to control my stuff. we cant find a wiring diagram anywhere so that we can trace the stuff to replace the part of the wire that burnt up
