Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-08-2004, 08:48 PM
crabby760 crabby760 is offline
95 ls questions
hello i just bought a 95 gsr model integra with a 98 ls b18b1 engine
the steering wheel makes a clicking noise when i turn it either way... its not the axels it is the steering wheel ... curiuos as to how i can fix that
also the back motor mount is tore up how hard is that to replace my self ?
also the srs light is on and the abs light is on too.. why is that
also maintnace required light is on how do i turn all these lights off?....
thanks alot in advance
Old 09-09-2004, 01:25 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: 95 ls questions
Replace the cv boot or the whole axle.
Gotta pull the motor out and get yourself an aftermarket one. IT'll last much longer.
I'd just take it to the dealer and see if they can fix it. I hate to mess with it myself. Do a major tune up for the maintenance part. I'm pretty sure thats what it needs if you haven't done that already.
Old 09-09-2004, 08:43 AM
It Isnt The Axel Its Fine!!!!
Old 09-09-2004, 10:38 AM
mellowboy's Avatar
Re: 95 ls questions
Only when you turn? It sounds like the cv boot bro.
Old 09-09-2004, 08:51 PM
but its the steering wheel that making the noise...
Old 09-10-2004, 12:41 PM
buildingmySI buildingmySI is offline
Re: 95 ls questions
is it a racing wheel or stock? either way, take the steering wheel off and check if anything is loose or broken. then put it back on. if that doesn't fix it buy another one.
and about the motor mount just get under there and check it out. i've done single motor mounts before and there not that hard to replace.
and for the dash lights go to a mechanic shop that does diegnostics and have them take a look. some times shops for get to reset the lights or fix something in the wiring.
good luck!
