Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 02-09-2002, 06:29 PM
paradyme paradyme is offline
Question Fuel Pump Lock Ring/How Do You Remove It?
Hey Iv'e been posting that my car is in need of a fuel pump. I tried installing the new BOSCH pump (pn#61075)yesterday and ran into this plastic locking ring that is a bitch to remove. You know I needed to know how to install it so I used the search bar to look for some online help along with some tips from you guys and someone here told me that there was this fastner or ring that would be trouble to remove, Well it's true and my 93' FSM (my cars a 95 G20t) suggest that a lock ring socket be used. This of course is a dealer tool! Does anybody have a suggestion here. The way it is made it looks like I could possibly use a large (truck type) oil filter wrench or a strap wrench. I could use some suggestions. It does not seem to tap loose with a screw driver.
paradyme
95'G20t/AUTO/BLK
STILLEN HEADER/INTAKE/JWT/ECU/S3 CAMS/P11 99 G20 RIMS/
VIPER SECURITY/w/ REMOTE START/ ALPINE AUDIO
Old 02-09-2002, 09:55 PM
Lightbulb
C'mon, can I get some help?
paradyme
95'G20t/AUTO/BLK
Old 02-09-2002, 10:14 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Just hold on. If someone knows they'll pipe up (I'm betting on George or APEX SE-R ) . Unless you want 50 'i donno' responses.
Old 02-09-2002, 10:27 PM
OKAY OKAAAY.
:flash:
paradyme
95'G20t/AUTO/BLK
Old 02-10-2002, 11:24 PM
P10DET's Avatar
P10DET P10DET is offline
Yep.
That ring is a BITCH.
I got it off by putting a flat blade screwdriver against the ribs and carefully tapped on the end of the hammer until is starter to move. Then I worked it by hand with a lot of, ah, magic words. :right:
You either need the tool or have some patience and tough it out. There is no simple answer. Sorry.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 02-11-2002, 01:13 AM
Talking
THANX! for the reply. I guess I haven't given the screwdriver a hard wack. That's because I'm a little self concious about the half a tank of gas sitting below me. I'm laying off the install for another week untill I get my all of the parts I ordered. I went ahead and puchased a replacment fuel pressure regulator and a gasket seal that will also need to be replaced with the pump. I also purchased two relays. If I sound like I don't know what is really wrong. That is because I don't for sure. But guess what? Neither does the dealer, And it's cheaper for me to purchase parts and figure this out than to have a dealer/mechanic ream me for hundreds of dollars. Plus I figure it's not going to hurt any to replace these parts at this stage. I have surfed the net and to your point I have found a How-To with pics of a guy replacing his fuel pump on a 95 GSX? (What ever that is) And he removes his lock ream using your same suggestion. My car is at a cross road. Iv'e never had any engine trouble or of any kind before this year so I figure It's just asking for some due time maintainance and pampering. she'll be getting a tune up at the end of the month alsong with a new front axle and control arms, high flow cat and new 5ZIGEN fireball exhaust. Check this out, this is those pics I mentioned.
http://www.twingles.com/twingles/den...NSO-2GAWD.html
:flash:
paradyme
95'G20t/AUTO/BLK
Old 02-11-2002, 01:22 AM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
you wanan replace those rubber rings as well..it's only about 8bucks from the dealer. once they are taken off (with screwdriver to carefully pry it) they get stretched and since it's alwasy in the gas tank, i heard its better to just replace them. That's what I did when i put in the Z32 fuel pump.
Luke C.
GDA Power!
Old 02-11-2002, 01:35 AM
Talking
What's up Luke, What rubber rings? I'm not sure what your refering too?
What's your email address I'll send you a pick of my G with the stock rims you sold me off your 99' Nothing private folks I just don't know how to post pics to a forum? DUH! Here's my email address: [url][email protected]
:flash:
paradyme
95'G20t/AUTO/BLK
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
1991 Fuel Pump Locking Ring vettenuts Escort 3 12-11-2004 06:28 PM
