Old 09-08-2004, 04:50 PM
jwjr jwjr is offline
Question knocking sound in engine
96 jeep cherokee. engine knocks when starting and when running but rides good. i don't know how serious it is but its sounds really bad. any suggestions on what the problem may be?
Old 09-08-2004, 09:26 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: knocking sound in engine
6 cyl, right?
Is it a knocking noise and not a valvetrain 'tapping' noise?
These Jeep engines are notorious for developing a piston slap, yet they will run very reliably for years while still making a noise. The piston slap is most noticable on cold start up and deminishes a bit.
Later Jeeps had a redesigned piston which reduces this problem.
Otherwise, it could be a rod (bad bearing) noise.
These noises are much more noticable at idle and under load. Engines don't last very long if a bearing is bad, and an engine rebuild is required.
Sometimes a worn oil pump can allow for a bad bearing noise only at idle when the engine is hot.
Thicker oil can help temporarily, but a new oil pump is usually the solution here.
