Old 09-08-2004, 04:16 PM
phoneman349 phoneman349 is offline
Angry 2001 taurus water in trunk wheel well
can't fiqure out how water gets in trunk wheel well. I close the trunk and use garden hose but no leaks are evident. When it rains and I drive it water appears any idea's?
Old 09-08-2004, 11:56 PM
Madcat455 Madcat455 is offline
Try this...
Get a bunch of paper... pull up your carpet around the spare tire well, and lay the paper down everywhere flat all the way up to the back seat, from side to side... overlapping is ok to make it fit nice. Then put the carpet back down(holds it in place)... Make sure everything is dry before doing this.
Next time it rains, go back there and see if there are any water trails on the paper, if there are, you should be able to trace them to the roundabout area where the leak is.
Old 09-09-2004, 05:15 PM
Re: 2001 taurus water in trunk wheel well
Originally Posted by Madcat455
Try this...
Thanks for the information. I will give that a try at the weekend, and let you know.................Keep dry!!!
Old 09-10-2004, 09:26 AM
mwt mwt is offline
There is a rubber grommet on the bottom of the wheel well.
It is a drain. I am pretty positive when you drive in the water it comes in thru there and is trapped inside. I don't believe it is draining in there from anywhere as mine doesn't do it unless I have been actually driving in the rain.
Mike
Old 12-10-2005, 10:27 PM
MooseNelson's Avatar
MooseNelson MooseNelson is offline
so what happens if you plug that hole?
Old 12-12-2005, 10:22 AM
killermrob83 killermrob83 is offline
Re: Re: 2001 taurus water in trunk wheel well
Nothing will happen if you plug the hole. The hole is there so that when the body is dipped during the manufacturing process there is a place for the liquid to drain back out. Just use a good pliable sealant to seal the grommet in place. That way if you ever have the need to drain the wheel well for any reason (leaving the trunk lid open overnight when it rains, spillinf a gallon of milk or whatever, etc.) you can still remove the grommet.
