Go Back   Automotive Forums Car Chat > Buick > General Discussion
Old 09-08-2004, 03:57 PM
circe circe is offline
dome light
I am replacing the headliner in my 1982 Buick. Have removed most of the trim but I am stuck on the dome light. Have removed the plastic cover but need to remove the unit, seems to be screwed in somehow, any suggestions or links? I have spent a long time trying to search out the solution to this problem and can't find any info.
Old 09-08-2004, 03:59 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
http://www.automotiveforums.com/vbul...play.php?f=727
this is the place you need to go to
Old 09-08-2004, 04:05 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
moved
Resistance Is Futile (If < 1ohm)
Old 09-09-2004, 10:24 AM
3000GT_Formula_350 3000GT_Formula_350 is offline
Banned
Not sure but, most of them are like this: Under the cover there should be at least two metal prongs coming down from the ceiling. Around each prong there should be two circular metal washer-like things. Those pry off and it should just drop out after that. Let me know if that helped.
