Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 09-08-2004, 03:43 PM
MajestikKnight03 MajestikKnight03 is offline
Noise from front wheel well
There is a noise coming from my front wheel well. It sounds a lot like a flat tire, but that is definitely not the case. I ran over a pothole like 3 years ago, but as of late the sound has started to get louder. Took the car to a mechanic and they said nothing was wrong. I was hoping one of you guys would be able to help me find a solution before I take it back to the shop. Any input would be appreciated. Thanks
Old 09-12-2004, 11:51 PM
galant06 galant06 is offline
Send a message via AIM to galant06 Send a message via MSN to galant06 Send a message via Yahoo to galant06
well that is an issue... and yes there has to be something wrong, I would check the placement of the tire and the disk, look if anything is rubbing the wheel and the entire joint system could be bent, Don't trust people in the shop, if you do end up taking it to the shop go in while your car is in the air and watch them look at it, and ask one of the mechanics to go on a test drive with you! any questions just say
Old 09-15-2004, 01:47 AM
Thanx!
Thanx for the tip. I'm gonna try and see if I can get the problem resolved next week. The car is still under warranty so I might take it into the dealership if I don't notice anything out of the ordinary visually.
Old 12-28-2005, 03:58 PM
1999mitjd 1999mitjd is offline
I same problem no one could find the noise but then i found that the transmission mount was bad cost $180.00 after i spent $700.00 on new struts but it did fix the noise so check trans. mount first.
Old 12-28-2005, 06:50 PM
Bronxbombr Bronxbombr is offline
Re: Noise from front wheel well
Ya it could be a mount or strut.
