Old 09-08-2004, 02:08 PM
Darb 2k's Avatar
Darb 2k Darb 2k is offline
Haynes or helms?
which one is a the better manual??? i remember reading something here about how one is better then the other??? thanks guys
also how hard is it to remove ur front bumber(89civic) is it a 2 man job to pull it off? cuz i have to replace a headlight soon. thanks
'89 Civic CX
Old 09-08-2004, 03:04 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: Haynes or helms?
I have the Haynes manual, and it's pretty complete. I have never checked on the other one... I do know that the Haynes has full wire diagrams (minus the speaker wiring), and also has full tear downs and re-builds. So... I would say keep asking.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 09-08-2004, 03:07 PM
Figori's Avatar
You have to remove your bumper to remove your light??? I guess I don't understand that since all I had to do on my 87 was unbolt the glass housing...
Old 09-08-2004, 03:24 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..there's really no comparison between haynes and helms.. www.helminc.com
SOLD!
Old 09-08-2004, 03:36 PM
Figori's Avatar
Wow... If you have the $56+ go for it. I just know that the Haynes manual isn't that bad... And only $16 at Auto Zone...
Old 09-08-2004, 04:27 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
both have usefull information, but the helms is definatly superior. If you dont have the cash you can download it here : http://texas.clubsi.com/brandon/crx/frame2.htm
Or you can read it online here : http://www.binghamtonlife.com/manual/2gsm/default.htm
Old 09-08-2004, 07:45 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Haynes is a comic book, get helms
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 09-10-2004, 04:48 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Chilton is the best but hard to come by cause I haven't seen another one. I bought it for like $26 I think and It's the best since I have both the helms and haynes. Look at your local bookstore cause I found mine at Barnes and Nobles.
Haynes is crap. Take my word!
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 09-10-2004, 05:31 PM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
What if you have a motor swap in your car, doesn't that manual tell you everything wrong?
Travis
Old 09-10-2004, 06:40 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
chiltons and haynes is absolute garbage. I threw mine away when I got my Helms.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 09-10-2004, 09:14 PM
vladlos's Avatar
vladlos vladlos is offline
Send a message via AIM to vladlos
yo, chilton all the way. they have super detailed instructions and information and good diagrams. to remove ur headlights you gotta remove ur front bumper.....its a one man job. then u gotta remove the metal filler piece under ur headlights....i think there are a few 10 mm bolts u gotta remove. then u can take off the headlights.....i think there are two 10 mm bolts under it where the filler piece used to cover up and there are two 10 mm bolts on top. i hope i didnt respond too late.
Old 09-10-2004, 09:36 PM
Forunn Daberator
yeah theres more bolts holding that filler peice on than their is holding the motor togehter.
Old 09-10-2004, 09:38 PM
Darb 2k's Avatar
so with that filler peice will i have to remove to replace my HL. if i do cant i just remove the filler piece rather than the bumper? also how many bolts are there lol
'89 Civic CX
Old 09-10-2004, 09:46 PM
Forunn Daberator
you have to take your bumper off first - two bolts behind bumper lights on each side, two screws in fenderwells. Once you take it all out it wont just fall off you have to lift up on it a little and it will come off, has little hooks that keep it on so its easyer to bolt up and stuff.
Then you will need to remove the side marker lights, two screws and they ever so gently slide out (more than likely jerking will be involved).
Then remove the filler piece, it has about 6 bolts I believe.
Then remove the headlight.
Old 09-10-2004, 09:56 PM
vladlos's Avatar
oye, i forgot about the corner lights.
