Old 09-08-2004, 01:10 PM
from_chevys2nissan from_chevys2nissan is offline
i need help LT1 back fire
my 93 LT1 camaro back fires when i get to about 3000rpm im tring to see whats the problem with it with out buy things i dont need. when i hit the clutch it ploow ploow ploow! then when i speed up to about 4000rpm and let off the gas it back fires too.
Old 09-14-2004, 01:40 PM
Re: i need help LT1 back fire
I Guest Know One Knows
Old 09-14-2004, 04:35 PM
LT1 Kayker's Avatar
LT1 Kayker LT1 Kayker is offline
Send a message via AIM to LT1 Kayker Send a message via Yahoo to LT1 Kayker
An engine can backfire for a few reasons. You could have a leak in your exhaust between your headers and your muffler where oxygen can get in and mix with combustable gasses and cause a backfire.
You could have a bad seal or leak in one or more of your cylinders that causes evil terrible used exhaust to go under your piston and screw up your oil that the crankshaft is in, or even combust under the piston and screw up your oil plus MAYBE even cracking the walls, but unlikely.
Could be your timing or a bad PCV valve with your I.A.C...
I would do a VAC test on it to check for leaks, other than that I don't know what else to say. Im not the most intelligent person ever...haha.
Or else im totally off, but these are just a few things that i've heard of making backfire happen.
89 Chevy C1500 - Over 305,000 miles on her but still going strong.
Cut off cat/straight pipe.
Flo-Pro muffler. (Flowmaster soon)
Dual 3" tips.
custom intake.
chrome valve covers.
uhhh and im poor so thats all haha.
Friggin truck costs more to keep alive than I do. (4ishMPG no joke)
Wait, let me get this straight...Your honda has 1.6 liters, but my bottle of Mountain Dew has 2!?
Old 09-14-2004, 04:43 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
my brothers trans am done that and there was and there was a hold in his exhaust, we put a new pipe on and it fixed the back fire problem
Old 09-14-2004, 08:43 PM
twdz28 twdz28 is offline
could be the opti too
95 Z28 Black on Black on Black. Mods: 355CI and lots more...
Originally Posted by Mordant
I'd say if they ask about material possessions then it's fair game to ask them what kind of underwear they wear, may as well get both sides expectations on the table as soon as possible.
Old 09-15-2004, 12:18 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
early design LT1 opti, check for visible signs of leakge under the waterpump, there is a small hole called the weep hole, if you can see traces of coolant coming out, then i can pretty much guarantee that its the opti. but also check to see that all your plug wires are on correctly, that means in the right order, and snuggly attatched to the plugs themselves. you could have debris in an injector causing a poor air/fuel mixure in one cylender, but i think opti is most likely.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
