Old 09-08-2004, 12:37 PM
quyeno quyeno is offline
metal plated car bodies
hi,
i'm considering several kits for my next project and i've seen a couple that have metal plated car bodies and was wondering what the point of having them metal plated when they will be sprayed over? does it give a subtle metallic effect to the paint?
Old 09-08-2004, 12:39 PM
Rtuned's Avatar
Rtuned Rtuned is offline
Re: metal plated car bodies
Originally Posted by quyeno
hi,
It's molded that color. And is plainly are for those newbie doesn't know how to spray color on model and like to have a chrome finish look. So they also don't know what is 'mold line'
Old 09-08-2004, 12:43 PM
that simple eh! ah well i don't think i'llbe spending that the extra cash for the privilege!
Old 09-08-2004, 12:46 PM
freakray freakray is offline
AF Modelrater
They aren't molded that color, it's an electro-plating they put on the body so it 'doesn't' need painting, if you want to paint the car you're better off buying the regular kit of the model to paint.
To paint the metal plated kits you'd need to first strip off the plating before you can paint it.
BTW, do a search, this subject hsa been discussed several times.
AF User Guidelines
Old 09-08-2004, 02:11 PM
blubaja's Avatar
blubaja blubaja is offline
Hey,
I have the Hasegawa WRX in the blue plated body. It's like the old spectraflame hotwheels. Chromed blue body. Not very realistic. But, neat I guess if you are like it liek that.
Frank X.
Old 09-09-2004, 06:55 AM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
Pre-painted kits from all manufacturers are bad! No matter how good the finish, there is always flash and mold lines left on!
However, I have yet to see the pre-painted and decalled Tamiya kit though.
Old 09-09-2004, 08:46 AM
I've seen the Le Man Porsche that tamiya does pre-painted and decalled, its looks very good and i didn't notice any mold lines on it. But IMO its taking out alot of the fun out of making the kit.
Old 09-09-2004, 08:47 AM
Vric's Avatar
Vric Vric is offline
even those that love the color, tamiya didn't even removed the mold line, so you need to sand them and the paint job is over.. need to do it again
Old 09-09-2004, 03:48 PM
dyowelb dyowelb is offline
so how do you remove the plating on these kits? i have a polor lights delorean kit that i want to strip of the plating but don't know how.
any help is appreciated.
thanks,
d
Old 09-09-2004, 04:17 PM
AF Modelrater
Why don't you check the FAQ for the section on stripping paint?
AF User Guidelines
Old 09-09-2004, 04:19 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
just soak the car in some brake fluid overnight and the paint will come off.
Old 09-09-2004, 04:30 PM
Re: Re: metal plated car bodies
thanks,
d
i did, but it didn't says anything about metal plated kit. so i thought that there's another or special way of stripping the plating off.
so, will CSC work on this types of kits???
Old 09-09-2004, 05:41 PM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
try bleach...it works good for the plating.
Old 09-10-2004, 04:05 AM
I was wondering, with all of these techniques to strip plating and paint off models, which method is safest to the plastic parts?
Old 09-10-2004, 07:27 AM
jswillmon's Avatar
jswillmon jswillmon is offline
Send a message via AIM to jswillmon
they are all safe for plastic parts, that's why there being suggested. Breakfluid is probally the quickest way. No matter what you use just make sure to check it, there is always an exception to the rule.
The only time i've ever had any problems stripping paint was when i left a pt cruiser convertible body in dot 4 break fluid for over a week and it completely dissolved just leaving the window frame of the windshield. 1 day would have been fine but i had alot going on and completely forgot about it.
The Name's Jesse!
**Click the pic for my latest build, Daytona Blue 350z**
