Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-08-2004, 11:58 AM
ImPLiCiTS14's Avatar
ImPLiCiTS14 ImPLiCiTS14 is offline
300zx parts????
I found a Z in the junkyard i have a 96 base s14 i was wondering what items i could use off of it. And what would be needed to make em fit.
For example the 4 piston brake system etc.
Thanks.
Old 09-08-2004, 12:05 PM
TatII TatII is offline
you can take the rotors, brake master cylinder, the calipers, the fuel filter, the fuel pump, the limited slip differential, the rear calipers. however everything mentioned needs to be combined with 240 parts for it to work. like you need to take the yolks from the 240 and put it in the 300ZX diff. you also gotta get a 5 lug hub from the SE models to put the brakes on properly.
www.importnut.net
his site will show you everything.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 09-08-2004, 12:17 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Re: 300zx parts????
If you are going SR20... you can also use the MAF.
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 09-08-2004, 12:59 PM
the MAF will work ont he KA as well. you just gotta let the ECU your running a larger MAF. or in some cases you can use the Apexi super AFC. however it doesnt' always work.
94 Acura NSX
Best E.T. 13.559
Old 09-08-2004, 01:06 PM
Re: 300zx parts????
tat how much boost you running?
Old 09-08-2004, 08:47 PM
9 psi.
94 Acura NSX
Best E.T. 13.559
