Old 09-08-2004, 11:55 AM
johnmcclen johnmcclen is offline
Unhappy Blazer eats alternators like popcorn
My 94 blazer has been through FOUR alternators. Sometimes the windings burn out but this last time the bearing failed! Also I can't seem to find a new one but have to rely on rebuilds. Was that just a lousy model year for alternators or could my truck have a gremlin that affects the windings AND the bearing? Great truck otherwise. GRRRRRR....
Old 09-08-2004, 12:12 PM
tom3 tom3 is offline
Re: Blazer eats alternators like popcorn
Can't imagine what's going on with that. Try an Autozone Duralast, at least it has a lifetime warranty and not too much more money.
Old 09-08-2004, 01:47 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Get a new battery.
A defective battery that is not holding its chanrge will wear the alternator out quickly seeing it is always constantly charging it.
Charge the battery before installation, don't just install it from the store, have it completely charged up.
BTW, don't you have the warranty for these alternators?
Old 09-08-2004, 05:04 PM
They check the battery every time and they say it's good. Would having to charge the battery make the BEARINGS wear faster? I mean I can see the windings but not the bearings.
Warranties. Usually the things last about 2 years and by then I've moved, lost the reciept, etc. This time I got a lifetime warranty though.
Old 09-08-2004, 05:09 PM
Butch Dennis Butch Dennis is offline
Usually when the bearings go out, it is due to either a bad rebuild or too much belt pressure. Being out of alignment with the other pulleys could do it also, but usually that will cause the belt to be thrown.
How long did the alt. with the bad bearings last?
Old 09-08-2004, 07:40 PM
I thought that but he said the belt tension was fine in this case. The one with the failed bearing lasted 3.5 years, longer than usual. He're a summary of when I've replaced alternators:
Replaced Lasted Problem
Aug-97
Aug-99 2 years died
Aug-00 1.0 years died
Feb-01 0.5 years died
Aug-04 3.5 years bearings started whining
Does a defective battery cause alternator wear because it just makes the alternator run more often, or does it stress it some other way?
This is really helpful guys thanks...
Old 09-08-2004, 08:17 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Have you always used the same re-manufacturer of these parts.
It just sounds like a bad case of rotten luck. Most likely these units
are the same for numerous models and years of S10 trucks, so
your particular year wouldn't be the exception.
If your battery has enough power to start the truck without a jump,
it's not requiring overcharging once the vehicle is running, as the alternator supplies all power necessary to run the truck (hence the alternator sends a charge >= 14V to recharge the battery and run the engine.
With the lifetime units, at least you only have the labor/time of replacing it (no charge for your time). I would have considered a larger output unit
from an aftermarket supplier (Napa) that has brand new units, not rebuilt.
Old 09-08-2004, 08:35 PM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Try going with a reman ACDelco unit or from the remanufacturer : WorldWide sold by Advance Auto and Partsamerica.com One more item, please tell me that no one has ever checked the alternator for charging by removing a battery cable with the engine running. That will cause a voltage spike and cause damage to sensitive circuits including those in the ECM and the alternator. If you are buying 1 yr warrenty rebuilds, you get what you pay for. In fact, did you know that you can buy a lifetime warrenty alternator from two different parts stores, and those stores buy their remans from the same remanufacturer? The reason this is important is because companies can specify how much they want to spend on quality parts. This turns into a lower price at the counter. I had the chance to speak with representatives at A1-Cardone remanufacturer. If the part looks like it was done in a 3rd world country, it probably was.
Old 09-08-2004, 10:32 PM
3 and 1/2 years is pretty good service.
I would be tempted to find a alternator rebuilding shop locally and have them replace the bearings in your alternator rather than replace it. Might cost a little more, but should be worth it.
Whatever might have been wrong and killing the old alternators sounds like it got fixed and you now just have to fix a mechanical defect.
BlazerLT's Avatar
AF -Advisor
Aug-97
Aug-99 2 years died
Bearings are usually a sign of piss poor workmanship. Are these AC Delco Remans or some shop?
Also, make sure you belt is the appropriate length for your specific truck. Go and get it referenced.
I hope you claimed warranty on these quick wearing alternators.
Old 09-19-2004, 08:32 AM
Smile Thanks Guys
I did get an alternator with a lifetime warranty so now if it goes again I'll only be out labor. Talked to the shop owner all about tension, the battery, etc and he said all that was fine, thinks I'm just unlucky. Thanks for the help.
Old 09-19-2004, 09:55 AM
BlazerLT's Avatar
AF -Advisor
Di it yourself.
Alternators take about 15 minutes to install.
Old 11-04-2004, 12:16 PM
troubles789 troubles789 is offline
The 91-94 alternator bearings are tension senstive. Make sure belt tensioner moves freely trough full range of its travel. Will eat bearing up if not right.
Old 11-04-2004, 01:45 PM
BlazerLT's Avatar
AF -Advisor
The sign of the bearing going is the high pitch humming coming from your engine.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-04-2004, 04:10 PM
Jeremy-WI Jeremy-WI is offline
Another thing that will burn up alternators are loose battery cables and the side posts like to loosen themselves
