Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 09-08-2004, 09:46 AM
big mike5j big mike5j is offline
97 Wont start, No fire to ign.
Help , I purchased this vehicle from a salvage pool. It had been hit in front, not hard, however it appears that it hit a curb or something similar as it broke the front axle perch on the left side (2 wheel drive). The real problem is that it cranks but wont start. It has no spark at the plugs. I put a scanner on it , and got no codes. I replaced the crank position sensor and it didnt change anything. I unhooked the fuel line under the vehicle and have fuel pressure. I have sprayed B12 in the intake and does nothing. Any help would be much appreciated
Old 09-08-2004, 11:38 AM
JDPascal JDPascal is offline
Re: 97 Wont start, No fire to ign.
First thing to check is the automatic shutdown relay and the fuse used to protect that circuit.
They should both be in the power distribution center.
After that, you are into the sensors and PCM.
JD
Old 09-09-2004, 12:23 PM
Thanks JD, checked those, all okay, any other thoughts.
Thanks Mike
Old 09-09-2004, 06:02 PM
BillD BillD is offline
Just a longshot, could the security system be at fault?
BD
Old 09-10-2004, 09:55 AM
Thanks Bill
From what i've been told that will let it start but then it will die.
I would like to get to that point at this time.
Old 09-10-2004, 03:04 PM
gean_yus gean_yus is offline
GOT A 1993 AND HAD THE SAME PROBLEM...TESTED THE RESISTANCE IN THE IGNITION COIL'S PRIMARY CIRCUIT, AND IT WAS OUT OF SPECS. REPLACED THE IGNITION COIL AND ALL WAS WELL.
Old 09-10-2004, 04:43 PM
YtseJam454's Avatar
YtseJam454 YtseJam454 is offline
You said it has no spark at the plugs. Does it have spark directly at the coil? Does it have injector pulse? You can check injector pulse with a noid light or a test light. If you have no noid light use a test light hooked to the negative batt cable. Disconnect a harness cconnector at the injector and find out which one lights the test light. Hook the test light to the + battery terminal and probe the other terminal on the injector harness connector. Have someone crank the engine. If it doesn't blink the PCM is not receiveing a signal to trigger the injectors.
Old 09-11-2004, 09:46 AM
Thanks Gean
I bought a coil yesterday on a long shot, Sure enough it fired right off with the new coil.
Thanks Everyone
Old 09-13-2004, 09:36 PM
Thanks Gean
Thanks Everyone
no problem dude! No If i can solve my missing idle problem all will be well.
Ken
