Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 09-08-2004, 09:18 AM
LEM LEM is offline
P0300 Code on 2000 Trooper
What are some common causes of the P0300 Cylinder Misfire code? I put Nippon Denso K16PR-P11 plugs in about 30,000 miles ago. I did have the EGR replaced and the EGR tube cleaned recently. Is there any reason to think these may be connected?
The Check Engine light blinks when I accelerate when I first start the vehicle, but goes away after I stop the engine and restart it later.
I thought I would remove the plugs and check them before I go ahead and order replacement plugs.
Any other suggestions?
Thanks,
LEM
Old 09-08-2004, 09:59 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: P0300 Code on 2000 Trooper
Your Intake Manafold gasket has a leak which causes a missfire code. If you are the first owner it is covered for 120k. If you are the second owner you are covered for 60k.
This a a very common issue with Isuzu's.
write up on how to change and part number:
http://www.geocities.com/endre_rl/isuzufaq.htm#faq5
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
