Old 09-08-2004, 12:39 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Need help w/ VAFC install
Hey all, I know it's been a while since I've posted up here, but I still know where to go when I need some serious knowledge! I just found me a VAFC to put in my CRX to finally make use of my VTEC engine, and was studying the install diagrams... I am looking at the ones on www.apexi.com, and I think that the wh1 (looking at http://www.apexi-usa.com/productdocu...afc_update.pdf ) is the right diagram, based on the pinouts, but I don't know what to do with the vtec input wire, and I think that I omit the VTM wire, is that right? I assume that where it shows an X on the diagram, I am to cut into the harness and run the signal through the unit, and where it shows a dot, I am simply to tie into the wire. Are there any other tips you guys and girls can offer me?
Thanks!!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 09-08-2004, 07:18 AM
91civicDXdude's Avatar
Re: Need help w/ VAFC install
you nailed it
Old 09-08-2004, 07:41 AM
4GZChatch's Avatar
so what about the vtec input wire? Do I just omit that too?
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
