Old 09-08-2004, 01:18 AM
nmroadrunner nmroadrunner is offline
Angry 97 died acted like vapor lock now ets lights on.. help!!
I have a 97 Grand Am. Went to the bank the other day, when i went to start it it acted like vapor lock. car would just make noise like it wanted to start but wouldn't. after a few it finally turned over.. drove it home. next day went to work.. came out it started.. drove it about 1 hour. shut it off in pkg lot. when i went to start it, it did the same thing.. cranks but wouldnt start.. this time it didnt start at all. now.. not starting ets off light is now on, this wasnt on before, also now after puting gas straight into the engine, it started for awhile but brakes seemed like they were gone. husband put a different fuel pump in from another car, said the fuel filter was real bad. changed that, were thinking of buying a new fuel pump but there 300$ and if thats not the prob, it could be costly with no solution to whats wrong.. any suggestions? I read in one post about the IAC in kick pannel and i did steam clean my car could that be it? pls help, we went and looked at a bunch of other cars today,, none compare to my grand am..
Old 09-08-2004, 11:31 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 97 died acted like vapor lock now ets lights on.. help!!
Grand ams have a body control module mounted in the passenger side kick panel. If your trouble started after you steam cleaned it, then you probably got water in it. They are a common problem with Grand Ams, and may be yours. Check the fuel pressure at the rail, if it's within spec, you can eliminate the pump as the culprit.
Old 10-13-2004, 05:44 AM
myowne myowne is offline
ETS light comes on without touching swicht on my grand am 1996 i'm woundering if you know anything about this problem is the control modul your talking about related to this ???? And let me add that this hapens wen im driving and the transmission jerks very briffely 3 or 4 time then it comes on then will some time go back off and do the same will hapen and wen it does that it runs nicely (no jerking) as long as the light is on (ETS off).
