Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-08-2004, 12:37 AM
lwrdcav lwrdcav is offline
steering wheel shaking
This has been a problem for a few months now. I just got new front tires on my SL2. I had them balanced but the mechanics said that the alignment was good. When i am going down the freeway around 75-80mph there is a tremendous shaking in the steering wheel? What could this be and how can i fix it? thanks
Old 09-08-2004, 04:04 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: steering wheel shaking
any difference accelerating/braking/crusing?
the tires may not be balanced right, the alignment may be off. CV joints may be unbalanced(rare). wheel bearing may be bad.
Old 09-08-2004, 02:54 PM
theres a little slipping when i break but it happens right when im about to come to a stop. other than that everything is fine.
Old 09-08-2004, 11:45 PM
may also be bad brakes, but the above is more likey i think.
Old 09-09-2004, 09:36 AM
i3o2Matt's Avatar
i3o2Matt i3o2Matt is offline
Send a message via AIM to i3o2Matt Send a message via Yahoo to i3o2Matt
if u turn the steering wheel to either direction and the shaking gets worse, then its most likely a wheel bearing...the same thing happened to my best friend's saturn...but it would kind of shake at around 35 on up, but there would be like a "thump thump thump" sound when he was goin straight...
Old 09-17-2004, 02:18 AM
My friend told me that something with my steering column could be stripped or loose...is this true? I still havent had time to take my car in to be balanced and aligned. But before i do that i want to make sure its not something big.
Old 10-10-2004, 02:32 PM
i just got my tires balanced. The shaking is not nearly as bad but it still does it when im going 75+ on the freeway. What should i do next?
Old 10-11-2004, 12:41 AM
still a handfull of things, but according to this niffty chart i have, it may be tire &/or wheel lateral runout. gotta have a shop to check to see if the wheel is true. i imagine unbalanced tires, if ignored long enough, could effect runout. i think i'm going to post this chart....
Old 10-11-2004, 02:15 AM
http://www.saturnfans.com/photos/sho...p/photo/15886/
