Old 09-07-2004, 06:12 PM
carman29906 carman29906 is offline
Send a message via Yahoo to carman29906
misfire?
i have an 89 2.0 5 speed and at low rpms it feels like its misfiring. at idle if i rev it up it almost sounds like its going to back fire. when im in gear accelerating it feels like the engine is boging down but only at a certain spot on the gas pedal to full throttle. i just changed the spark plugs and wires and cleaned the throttle body and still doing it.
Old 09-07-2004, 07:04 PM
jayson716 jayson716 is offline
Re: misfire?
try cleaning the injectors. then get a coputer to hook up to it and see if there are any codes or anything misfiring,
-Jay Jones
Team DROPZONE
Vice President
Old 09-08-2004, 09:19 PM
Catvalier Catvalier is offline
Re: misfire?
Misfiring can be tough to gauge even with a good ear. Spark and fuel can be the issue in this matter. If you get moisture on the plugs it can cause both, but I would chase water in the tank for starters. If you received a bad batch it can clog the fuel filter as well.
Old 09-09-2004, 01:01 PM
Re: misfire?
Something really weird is going on with my car i just reved it up and it boged all the way down then backfired and shot a flame about 2 feet ou of the throttle body and now it runs fine better throttle response than before. i dont know what happened but im going to keep an eye on it and hope it stays like this. thanx alot for the info though.
Old 09-09-2004, 03:28 PM
public's Avatar
public public is offline
Re: misfire?
Clean/replace your fuel injector. They can spray uneven creating a super rich mixture on the intake that will do this. Also clean your IAC. It can cause this as well. Good Luck.
