Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-07-2004, 06:06 PM
ttope ttope is offline
bad fuel pump?
Have a 96 5.9 Ram 2500. Will start but doesn't want to idle. Will idle after some time after running. Thinking it might be the fuel pump or fuel filter. Is the fuel pump in the gas tank? The fuel filter also? Thanks
Old 09-07-2004, 08:09 PM
TurboSW's Avatar
TurboSW TurboSW is offline
Question for you. Does it stay running while it's in park? Does it stall when you put it in gear? I ask because I ran into the same kind of problem about 3 years ago. It turned out it was the battery and had nothing to do with the engine itself.
Old 09-08-2004, 08:27 AM
when I have had it started it ran fine.
Old 09-08-2004, 12:01 PM
GreenlandMopar GreenlandMopar is offline
Re: bad fuel pump?
you might want to check out your idle sensor.. it could be that and yes the fuel pump and filter are all in the tank ichanged mine it was 350.00 and took me about an hour and a half
Old 09-08-2004, 06:45 PM
TurboSW's Avatar
Re: Re: bad fuel pump?
So you changed out your Pump huh. Was it a pain to drop the tank and crap? I need to change mine out because the fuel gauge doesn't work anymore and I'm told the sending unit is all in one with the pump and filter. Any tips you can give me on the job?
Old 09-09-2004, 12:58 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: bad fuel pump?
A guy I went to school with raised his box up instead to replace the sending unit for his fuel gauge. I'd ask him about it but I don't know where he is.
The box is pretty simple to unbolt and raise up with a jack-all. If you have like 5 other friends you could probably pick the whole thing up and just walk away with it.
My Mopars
Old 09-11-2004, 03:00 PM
beaker01 beaker01 is offline
Re: bad fuel pump?
I looked into gettin a fuel pump for mine and found it @ Auto Zone for $244. I haad found out my cat converter was plugged and acted like that.
Old 09-12-2004, 01:58 AM
BleedDodge's Avatar
Re: bad fuel pump?
Yeah I know what that's like. When the cat's plugged you'd almost never guess what was wrong.
My Mopars
Old 11-09-2004, 09:17 PM
Russ_M Russ_M is offline
Send a message via Yahoo to Russ_M
Re: bad fuel pump?
replacing the fuel pump is pretty easy dropping the tank.....bu It sounds like the cat.......unhook the pipes at the manifold and see what happens. Save yourself a buck or two.
