Old 09-07-2004, 04:38 PM
DTalon DTalon is offline
Water in engine..may need rebuild??:S
i own a 95 eagle talon, the performance intake and filter which was installed sits low 2 the ground, and when i hit the water it sucked it up into the engine...the car coughed a couple times, then stalled, n hasnt started since....i pulled out the spark plugs, changed the oil, and took out the starter and tried to crank the flywheel but found it only turned about half way..mecahnic that looked at it thinks its the crank....ne1 know where i could get this fixed or possibly rebuilt 4 a reasonable price...thanx, D
Old 09-07-2004, 09:18 PM
Re: Re: Water in engine..may need rebuild??:S
ya i thought of that 2...only problem is i still have my g2 license....i juss turned 18....ive bin insured with this veichle 4 only 1 month...so it will b pricey from here on out if i claim it...i also have a 1 yr warannty on engine and powertrain only problem is they want 65 bucks 2 activate it then all the money it may cost 2 diagnose the pronlem with THEIR mechanic...n then they tell me if they can cover it or not...n the coverage is only up 2 750 dollars which doesnt seem worth it....
Old 09-07-2004, 09:58 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
insurence wont pay for water sucked up through a aftermarket CAI
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 09-07-2004, 10:33 PM
Juggalo Juggalo is offline
yea i tried to talk to my insurance too when i did the same thing.. my engine was shot i did alot of damage.. threw a rod threw my oil pan and everything damn CAI!!! lol oh well it was an expensive lesson at the least..
Old 09-07-2004, 11:02 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
that sucks. im glad i read this thread. never put filter where water can reach.
Old 09-07-2004, 11:06 PM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
my cone filter sites very close to the fuse box so i figure if water s commin that far up i got worse problems... lol
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 09-08-2004, 01:57 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
I hydrolocked my engine pretty bad too. But that's cause I injected water into it! I took it to a shop and it cost $1100 to get it fixed. In reality, it probobly could have cost no more than $200 to fix it myself. And it was $600+ in labor. Unless you tried to start your engine after it died or you were stepping on the gas while it was hydrolocking, it shouldn't have bent anything. But it could have, you never know.
I read a lot on CAI's and the conclusion was that it is almost imposible to suck up so much water to hydrolock your engine unless your driving through a puddle that covers your filter completely. If you want to avoid any possibility of the problem you can put a little filter like the ones used instead of a oil catch can on the upper part of your intake. Then, when your filter is completely submerged, the second filter will start sucking in the air.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 09-08-2004, 05:27 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
did you put the tranny fluid in the cylinders like i told you to in the other thread? DO IT! its worth a try... or buy a new motor/rebuild the motor!
Old 09-08-2004, 12:51 PM
ya man i tried the tranny fluid.....juss letn it sit then ill try it out with the breaker bar...
the problem with my air filter is it was dropped down low...VERY LOW....i think it wasnt compltely submerged in water but...enough to do damage...
Old 09-08-2004, 01:28 PM
EclipseRST's Avatar
Banned
well if that doesnt work your motor is fucked... so you might as well start looking for a new block... either that or buy a rebuild kit!
Old 09-08-2004, 07:38 PM
after i put the oil back in...and the spark plugs and the breaker bar doesnt work...should i try starting the car again from the ignition?
Old 09-09-2004, 02:49 AM
EclipseRST's Avatar
Banned
its not gunna happen... if you cant turn the motor over with a breaker bar then the starter is definately not goin to be able to turn the motor over! its over, you hydro-locked your motor, start looking for a new motor or new piston rings and rod + main bearings
