Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 09-07-2004, 03:36 PM
Nube Nube is offline
Angry HELP Starting Problems
I recently just bough a 2000 LS V8 and it is having some starting problems. When you go to start it all it will do is crank, it takes up to 6 times before it will start. Does anyone know what it could be. I had the fuel pump replaced but that did not fix it. PLEASE HELP!!!!!
Old 09-08-2004, 08:58 AM
CGGorman's Avatar
CGGorman CGGorman is offline
Re: HELP Starting Problems
I believe there was TSB for this issue. The fix involved a Reflash of the PCM. IIRC, the problem occured occasionally when the engine shut down with the exhaust valves open on cylinder #1. With both valves open, the engine can't get compression when cranking and won't start. Something like that, anyway... Your dealership should do a search of the TSB listings.
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
