Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 09-07-2004, 01:16 PM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Turbo - Before Throttle vs. After Throttle
What advantages does one have over the other if any?
Old 09-08-2004, 04:22 PM
SaabJohan SaabJohan is offline
Re: Turbo - Before Throttle vs. After Throttle
Only "throttle after turbo" is used, except a few cases which used the throttle before; for example some of the turbocharged F1 engines from the eighties.
I think the purpose of placing the throttle before the turbocharger was to keep the turbocharger up to speed when going off the throttle.
The obvious downside is that the volume that will be put under vacuum is large, giving increased throttle lag. With the throttle before the turbocharger the turbocharger must have a seal that won't leak out oil during vacuum, which a normal turbocharger will do.
Old 09-08-2004, 05:42 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
Is oil leakage and throttle lag the only problem with a turbo that has the throttle valve before it? Does it pose a significant problem with performance?... if so what are the benefits of having this configuration?
I disregard my perceived image in the persuit of knowledge.
Old 09-10-2004, 09:55 AM
Oil is leaking due to the vacuum in the compressor with a closed throttle when placed before the turbocharger.
Old 02-04-2010, 09:38 PM
yardy yardy is offline
How could I eleminate the issue with the seals as Im interested in building a fast and efficient 4WD MK2 Focus (European)
