Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-09-2002, 10:50 AM
95vteclude
Guest
Posts: n/a
Heres my dyno run...
1st run (blue) max power = 160.4 hp max torque 144.9
2nd run (red) max power 160.6 max torque 142.8
And below is my air/fuel ratio which shows my car is running super rich is causing me to lose HP. I have bosch platinum plugs in there and the guy told me they were junk and that i shouldnt put anything but NGK's in. My only engine mods are a short ram intake and a ractive exhaust. If its not the plugs causing it to run so rich what are my options to fix this? vtec controller?
Old 02-11-2002, 12:09 AM
95vteclude
Guest
Posts: n/a
no comments? i was hoping someone would at least say if this was decent or not for a relatively stock 4th gen...
Old 02-11-2002, 05:58 PM
PTOWNPRELUDE PTOWNPRELUDE is offline
Send a message via AIM to PTOWNPRELUDE
Uhhhhhhhh..........good job. lol There is a comment for ya but seriously that's pretty impressive man, also about the platinum +4 bosch plugs, I have some also in my Lude and I was wondering if what you said about them came from a reliable source cause I mean I payed like 30 bucks for the four of them.
"Dude, where's my car?" "Where's your car dude?" ~ Jesse and Chester from dude where's my car probably the best lines ever said in movie history lol
Old 02-11-2002, 07:04 PM
95vteclude
Guest
Posts: n/a
he's pretty reliable... he's a friend of mine and was a mechanic for honda for 4 years.. unfortunately, he's now at volkswagen.. i wish he were still at honda because he would hook me up..
Old 02-11-2002, 08:49 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
Pretty standard curve. That's right where I would expect it to be. Stock manual 4g VTEC & 5g ludes usually put around 165 to the wheels. What gear were you in for the run?
You could probably get a few more ponies and maybe a slightly better MPG by running a piggyback a/f controller like the Apexi VAFC to lean out the fuel a bit.
Dump the +4 plugs. I'm embarrassed to say I got suckered too - I don't know what I was thinking. It took about 2 months before one started to fall apart (ceramic seperated from the metal). Went back to the stock NGK platinums - couldn't be happier. Heard generally good things about the iridiums as well (both Denso and NGK).
Old 02-12-2002, 09:26 AM
How much would iridiums run for price? and what kind of horsepower increase?
Old 02-12-2002, 01:05 PM
95vteclude
Guest
Posts: n/a
thanks fritz.. thats the kind of response i was looking for... And to answer your question I was in 4th gear on the dyno.
any ideas on why it would be running so rich to begin with? . I was thinking it could be a couple of things. first, the plugs... i'll be getting NGK's by weeks end and I havent changed the fuel filter yet either... the car has 78k on it and its probably due. i bought it with 56k on it 2 years ago and i dont know if the previous owner ever changed it.. i always assume the worst case. i just changed the wires/cap/rotor a month ago. so that should be fine. and I think the injectors are dirty. hence my question in the tech forum about fuel system cleaners. I'm hoping that once i get all this done it will balance out the system and i wont need an vafc controller.
Old 02-12-2002, 01:14 PM
supafly1024's Avatar
supafly1024 supafly1024 is offline
Ludes run rich from the factory.
Old 02-12-2002, 02:05 PM
4bidden 4bidden is offline
Send a message via AIM to 4bidden
are vafc's really worth the $300 that they cost?
-Jeremy | [email protected]
Old 02-12-2002, 06:29 PM
fritz_269's Avatar
At startup and at WOT. I don't think they're pretty stoich at part-throttle when the engine's warm.
They engineer this richness in to help keep you out of detonation, particularly if you get a bad tank of gas, or are driving in very hot weather. If you lean it out with a VAFC, be a little more wary of these problems.
4bidden - What do you mean by "worth it"? They work as advertised. The Fields controller is a little cheaper but less adjustable - but those two are about your only choice for an H22 VTEC & A/F controller.
dyno run kmak686 911 0 04-08-2004 11:23 PM
Power/Torque graphs or Dyno runs Tanked '88 - '91 Civic | CRX | Wagon | Shuttlee 2 09-07-2003 01:20 PM
Results of dyno run 00'Civic SR Europe 9 04-22-2002 11:17 AM
dyno runs scan General Discussion 0 01-22-2002 10:12 PM
My DYNO Run PranK General Discussion 16 11-22-2001 12:11 AM
