Old 09-07-2004, 12:12 PM
jmob jmob is offline
drivetrain help
hey people,
i have a 94 camaro w/ v6 3.4 . i believe my center support bearing broke. it clunks and thunks when i drive and the back end vibrates . i look under the car and notice the support bearing was loose and broke. the thing is u cant buy a new support bearing - you have to buy a hole new drivetrain or driveline, it cost 834.00 dollars from chevy! does anyone no what i should do? or how i can fix it
Old 09-07-2004, 01:55 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: drivetrain help
um, i dont know about all that. if the only thing that is damaged in the bearing on the driveshaft than that should be 100 bucks tops to replace. so long as nothing else is effected you can just go out and get a new driveshaft. actually i would recommend getting one off a z28 that way you have a one piece and wont have to worry about it again. that is if you can deal with the added vibration that the car will have with the one-piece...
*Better power-to-weight ratio than a C6 corvette*
Old 09-07-2004, 05:39 PM
Dober89 Dober89 is offline
Re: drivetrain help
Are you talking about the torque arm that runs beside the driveshaft??? If thats what you mean, chances are you just broke the mount. You can get a replacement GM mount from the dealership or you can upgrade to a poly mount which is stronger but harder too.
Old 09-07-2004, 07:51 PM
Re: drivetrain help
it cost 50- 70 bucks for the center support bearing plus labor to fix at one place in albany. but i need to take the old driveshaft off and bring it there. so that means find someone with a lift. i called a used auto parts junk yard for a price on a driveshaft and found one for 125 buck and anthor place for 50 bucks. 50 bucks yeah baby i hope it fixes it. i gunna save some money. gm parts are alot.$$$$
unless anyone knows where i can get a cheap aftermarket driveshaft from. thank 4 everyone who replys
Old 09-07-2004, 09:55 PM
firebird69racer firebird69racer is offline
Re: drivetrain help
jmob
Look for a driveshaft place near you, they can make a one piece shaft for you. Its what my son did on his car. and there is no vibration at all.
We called all around here and nobody serviced the support bearing at all , not even the driveshaft place that made the one peice for us.
If you dont have a driveshaft place neer you then do a search on line
I woulndt trust a used one, who knows how long it will last.
With a one piece you will never have to worry about it anymore.
Wade
Old 09-07-2004, 10:11 PM
EclipseDriver95 EclipseDriver95 is offline
Send a message via MSN to EclipseDriver95
Re: drivetrain help
Thats true i would go with a 1 piece, and have 1 specially mad, it would be good!
[size=7]
[center]MY 1996 Z28
Old 09-08-2004, 03:43 PM
Re: drivetrain help
Will the aluminum shafts from the LT1 and LS1 cars not fit directly in place of the crappy two piece V6 version??
