Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-07-2004, 12:39 AM
Ben999_ Ben999_ is offline
Send a message via AIM to Ben999_
Intrument Cluster Replacement Possible?
I have a '91 5.0L Tbird and I haven't had any complaints with it except that the instrument panel only has 3 gauges, the temp gauge, speedometer, and fuel gauge. Also the speedometeter only goes up to 85 MPH. I know the SC models have additional gauges including a tachometer, and the speedometer goes up to 120. I'm wondering if it is possible for me to replace the entire instrumental panel with one from an SC model of the same year and gain use of the additional gauges or at the least, the gauges I already have along with the new speedometer. Has anyone tried this before?
Old 09-07-2004, 07:19 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: Intrument Cluster Replacement Possible?
3? Thats all? I recently grabbed a cluster from a junk 89-93 V6. It had volts, gas, oil pres., water temp, speedo, and tach (7) It also sounds weird that your speedo only goes to 85 (the one i got goes to 120, and only on some, does the speedo go to 140)
I've changed my entire gauge cluster unit in my car about 4 times. Its a major pain in teh ass. I used the cluster from the 89-93 in my 94, with no problems (with the exception of a broken fuel gauge). Since your car never came with the tach, volts etc. I doubt you have the wiring and components for them. You could try it though. Complete gauge clusters at my u-pull it are only $14.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 09-07-2004, 08:02 PM
So you think the speedometer, temp, and fuel gauges would work with the new cluster? If all I get out of it is a higher speedometer than I think it would be worth it. My cluster looks like this one, without the white backing http://www.geocities.com/slhrbacek/89Faces.html
Old 09-07-2004, 09:23 PM
Also, assuming this works, is it hard to roll back the odometer?
Old 09-21-2004, 10:33 AM
Thanks for the help, I went ahead and bought the cluster and put it in. Everything works fine, the only difference is that the extra gauges are not wired in the non-sc tbird so they read nothing but still look cool. I also installed EL lighted gauge overlays yesterday, looking very nice. Here are some pics:
Thanks for the advice.
Old 09-21-2004, 12:03 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Don't roll back the odometer. Unless you want to go to jail!
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 09-21-2004, 02:21 PM
i rolled it back to the exact same mileage on the stock cluster. So nothing changed.
Old 09-21-2004, 04:51 PM
Oh sorry I feel stupid now. You mean rolling back to your original mileage sorry.
Old 09-21-2004, 07:14 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Technically, that is illegal. When a speedo is replaced for any reason a sticker is supposed to placed on the new speedo head with the details of the change.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 09-22-2004, 12:42 AM
Mike75 Mike75 is offline
Looks great, Ben!
But something's telling me you should check the engine...
Old 09-22-2004, 09:34 AM
thanks, yeah i had that checked right after i got the car. it comes on after i drive it for like 20 minutes, it's a problem with the EGR valve. The mechanic said it's not a serious problem and i should replace it sometime but not run it like that forever.
Old 09-22-2004, 07:10 PM
Where did you get those inserts, by the way?
Old 09-22-2004, 08:49 PM
i was fortunate enough to snatch them off of ebay. It was 2 sets of overlays, only the speedometer overlay was missing in the second set. I forgot to take a pic of the control module i mounted next to the headlight knob. I can switch the color to green and also dim it.
Old 09-23-2004, 12:06 AM
nice
