Old 09-06-2004, 11:52 PM
Gateway's Avatar
Gateway Gateway is offline
Question for people who have the stillen race pipe
Is it able to be installed yourself? easily?
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 09-07-2004, 03:03 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
I don't have a stillen downpipe, but if you look at it, all that is needed for installation is of the utmost simplicity.
The downpipe just bolts directly to the exhaust manifolds, and since it eliminates the cat, you'll have to remove that as well as your stock downpipe. I installed a test pipe on my 3000GT the other day...very easy, took about 10 mins. Just a matter of unbolting, putting on new exhaust gaskets, then bolting the new pipe in.
The one slightly difficult part you might run into when installing a downpipe is reaching the exhaust manifold bolts. Just make sure you have the car jacked up high enough for you to get under there and use some elbow grease.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-07-2004, 02:26 PM
Igovert500's Avatar
blue + red light magnet
Re: Question for people who have the stillen race pipe
Use PB blaster the night before, just douse(sp?) all the bolts, they will come off a hell of alot easier the next day.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
