Old 09-06-2004, 10:18 PM
Fireforge79 Fireforge79 is offline
Exclamation need help fast on a Distributor
Will a 90-91 Si distributor work on a Mini-Me set up???
Old 09-06-2004, 10:52 PM
Hybrid1990crx's Avatar
Re: need help fast on a Distributor
yes, but i think you have to notch it out.
Old 09-06-2004, 11:20 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
yeah I read something about you have to modfify one of the bolt holes that bolts it to the outside of the head I believe.
Old 09-06-2004, 11:43 PM
CRXsiZCpa's Avatar
CRXsiZCpa CRXsiZCpa is offline
Yeah, it will work but you do have to custom fabricate one bolt for the dizzy. 2 will work fine, I know a few people with mini-me's using only 2 bolts to hold the dizzy on.
Old 09-07-2004, 12:18 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: Re: need help fast on a Distributor
it will work only if you use the pm6 ecu + si intake mani (including injectors). then you'll need an RPM activated switch
i've heard of only using 2 bolts as well...but thats sorta to me
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
