Old 09-06-2004, 08:27 PM
Hybrid1990crx's Avatar
Car feels sluggish.
Ok so my 90 si doesn't run as fast as my 89 si did. A friend of mine said I may be feelign this because my 89 had a bumped up compression a bit from the z6 headgasket and had a 421 header on it. I don't think its because of that.
I am throwing a code, but its a 17, speedo sensor. My 89 had this before too and didnt cause any problems.
The previous owner of the car replaced the map sensor and said this may be the problem still.
The car runs fine, idles great, revs all the way to redline, doesn't smoke or anything, seems to be a strong motor.
What would you guys sudjest for me to look at first? I have a whole nother car for parts so I can replace anything i need to. Thanks guys.
Old 09-06-2004, 08:53 PM
vladlos's Avatar
vladlos vladlos is offline
Send a message via AIM to vladlos
i'm kind of having the same feeling with my 91 standard. it feels like it ran better a month or two ago. i'd suggest a basic tune up, oil change, and some of that injector cleaner stuff.
i talked to this one dude i know who only works on hondas and acuras and he told me that it can be sort of sluggish because of my axle because my cv joint is shot. i'm having a feeling its crazy talk.
Old 09-06-2004, 08:57 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
car feels sluggish
you might wanna try to start off with fixing the speed sensor,
its on the side of the head,below the distributor,
also,check to make shore your catalic convertor isnt getting clogged,
besides that,if your computer isnt throwing any more codes,you know there isnt any electrical/sensors gone bad,
make shore your getting a good fuel flow,cause if somthings getting clogged in the fuel system,your not gonna get the fuel you need when you hit high rpms,which needs the use of more fuel,wich will make your car run a little sluggish,
check your fuel filter,pump & the injectors.....
In the process of B00stin my D
Old 09-06-2004, 09:18 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Car feels sluggish.
Basic tune up (fuel filter, pcv, cap/rotor, wires, plugs, clean the injectors, oil change). Worn axels/cv's can cause it to feel a little more slugish because of slack in it, but more than likly its not that noticable.
Old 09-06-2004, 11:00 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Is it sluggish only at a certain rpm? If its slow in the lower or higher rpms only then take a look at timing, may have slipped a tooth or somethng.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 09-06-2004, 11:11 PM
Nah, I think its slow all the way through the RPM band. I was thinking timing at first to, but I'm not sure anymore.
Old 09-06-2004, 11:17 PM
Forunn Daberator
maby its just slower, some cars are just that way.
Old 09-07-2004, 02:55 AM
GTA's Avatar
GTA GTA is offline
Whee..
its heavier than the 89, that may be a reason
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 09-07-2004, 09:08 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Tune up - fuel filter, injector cleaner, oil change cap, rotor and plugs.
Maybe you could swap your 4-2-1 header and the rest of the exhaust. Didn't you switch to a CAI? There may be some restriction if you're still running small pipes. It could also be that the car is heavier too.
EDIT: I just looked at the pics of the new Si hatch again and noticed the CAI (short ram) is on old car though you may have switched it over.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 09-07-2004, 10:48 AM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
my bet still stays on your lower comp less mods
Old 09-07-2004, 05:32 PM
Turtle, No cai. That wasn't cold air on my 89 anyway. I'm keeping the stock airbox, its gutted and has a K&N. Works good and looks clean. Thats how its staying.
Old 09-07-2004, 08:03 PM
do a leakdown test on it and see how well your combustion chambers are sealing up.
ZC stuff
Old 09-08-2004, 02:30 AM
CRXsiZCpa's Avatar
CRXsiZCpa CRXsiZCpa is offline
How the valves sound? Mite need clearence. And do basic tune up like cap+rotor, plugs, wires, fuel filter.
Old 09-08-2004, 06:00 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
well if you are throwing a code maybe your car feels slow cause it is in limp mode. Try to get that CEL light gone 1st.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
