Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 09-06-2004, 03:51 PM
joeygarcia joeygarcia is offline
Send a message via AIM to joeygarcia Send a message via Yahoo to joeygarcia
92 Explorer Deisels
My 92 4x4 explorer diesels when I return from a drve and turrn off ignition if i let the car sit for a bout a miute or so and the idle will drop from 1000 to about 500 then I can turn off and wont deisel ,It also does it most when I run the A/C ....
Thanks for some info...
Old 09-07-2004, 03:42 PM
lefty13lefty lefty13lefty is offline
sounds like you have a vacume leak, or possibly the charging system, it could be the alternator, with the a/c compressor running it takes away almost 40 percent of your power, low charging system could cause the motor to run bad, I reccomend you get a meter and put it on the battery and see what its charging at it should be charging about 14 volts. let me know what happens.......GOOD LUCK
