Old 09-06-2004, 02:25 PM
proformancewanabe5 proformancewanabe5 is offline
Power Antenna
I have got a 98 GSX, the antenna won't go down. maybe the fuse is gone, or the antenna motor is fryed. I figure to buy the stock unit will cost an arm and a leg or are they universal any help thanks.
Old 09-06-2004, 02:33 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: Power Antenna
i kno a guy that ripped his out of his mr2 spyder (same design primarily) and got a short one from a S2000 and it looks clean
they should be universal depending, i'd go w/ one built into the rear window or something of a different style if i were you
Don't act like you don't love it.
503/2000
Old 09-06-2004, 03:52 PM
george536's Avatar
george536 george536 is offline
Re: Power Antenna
maybe its getting no signal from the stereo. i have an aftermarket stereo and it wouldnt go down i looked at the wires and they werent connected to eachother. mite wanna check that.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 09-07-2004, 12:13 AM
Julioluko Julioluko is offline
Re: Power Antenna
yeah buddy i was just tearing mine down yesterday It might just be the strip that gets pushed up and down just went off the track, or it could be the moter just went on it, But anyways your just going to tkat it off and see, And you can get just a universal from advanced auto, they will all work fine. And actually the one from advaced auto looks very similer to the factory one.
