Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
View Poll Results: dash lights stop working after factory stereo was removed does anyone know how to fix
help fix dash light that stopped working after factory car stereo was removed 1 50.00%
dash lights stopped working when car stereo was removed 1 50.00%
Voters: 2. You may not vote on this poll
Old 09-06-2004, 01:43 PM
OLD_SKOOL_MAX OLD_SKOOL_MAX is offline
Dash Lights Out After Removed Factory Radio.............does Anyone Know How To Fix?
when I Bought My 1987 Nissan Maxima and It Had No Car Stereo In It And The Dash Lights Never Worked But When I Put In A Aftermarket Radio The Dash Board Lights Still Don't Work And I Have Tryed Looking At The Wiring But Cannot Find Anything......................does Anybody Know How To Fix This Problem??????? Please Help!!!!
I Also Found That This Is A Common Problem But Cannot Find Anyone That Knows How To Fix It Or Have Yet To Speak To Anyone That Has Had This Problem.
Old 09-06-2004, 11:13 PM
Igobuk Igobuk is offline
When you turn on your lights in any car, there is always a wire that receives power as well in the dash area of your car and lights up your dash. So what I suggest is you get a Chilton or Haynes manual with a wiring diagram and find the correct color wire to test for and make sure it's getting power when it's supposed to. If it is, then check the bulbs in the cluster.
If it isn't, then do a ghetto fix, and just splice in a wire from your parking lights so that when your parking lights light up, they send power to your dash cluster. Problem should be solved... assuming the bulbs in the cluster aren't burnt out.
Also, check the dimmer switch... the dimmer switch, if turned all the way down, will cancel power from being sent to the dash lights, so if the dimmer switch is broken, it may not be letting power get to the dash.
Old 10-03-2004, 04:28 PM
mikesilvia415 mikesilvia415 is offline
Send a message via AIM to mikesilvia415 Send a message via Yahoo to mikesilvia415
Re: Dash Lights Out After Removed Factory Radio.............does Anyone Know How To Fix?
its a fuse most likely
