Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 09-05-2004, 11:59 PM
bobrep bobrep is offline
Unhappy O2 sensors, Knock sensor, EGRC Solenoid Valve
On my Nissan Maxima SE'95 I had Check Engine Light couple days ago.The ECU code was 1005. I just reset the ECU and today the light is on again. Now I have 4 codes:
0303 - Front Left Heated O2 Sensor;
0304 - Knock Sensor;
0503 - Front Right Heated O2 Sensor;
1005 - EGRC Solenoid Valve.
What should be replace? Will problem be resolved when I replace sparcks? HELP ME PLEASE.
Old 09-06-2004, 10:55 AM
THT THT is offline
Re: O2 sensors, Knock sensor, EGRC Solenoid Valve
Replace your O2 sensors first then the KS code will most likely go away.
~THT
Some people call it an obsession; I call it my Maxima.
Old 09-06-2004, 10:42 PM
Thank you very much. Should I replace EGR Solenoid Valve first and after the O2 sensors?
Old 09-07-2004, 07:46 AM
THT THT is offline
EGR probably needs a cleaning is all; have you ever cleaned it?
~THT
Old 09-12-2004, 06:36 PM
Re: Re: O2 sensors, Knock sensor, EGRC Solenoid Valve
~THT
No, I have never cleaned it. It's very hard to locate that valve. Where is it? I checked the "Nissan Maxima 1993-98 Repair manual" (ISBN#0801989612 )and there is no word about that valve. There is information about engine VE30DE. My Maxima has VQ30DE (Maxima'95).
Even on page 4-30 the image of the engine and the name of it are switched. So, it's very hard to use that manual for VQ30DE engine. Please, provide me more information where it is and how to clean it if it's not hard for you.
THANK YOU VERY VERY MUCH!!!!!
Old 09-14-2004, 12:27 AM
THT THT is offline
Look under "Exhaust gas recirculation"; found it in my Haynes manual in thirty seconds. I'd scan it but my scanner's out of commission. And if the cleaning doesn't do it, replacing the solenoid should take care of your problem.
~THT
