Old 09-05-2004, 09:55 PM
Gateway's Avatar
Gateway Gateway is offline
Help! Confused about 3sx downpipe and stillen race pipe
Ok, I've been to this page:
http://www.stillen.com/Sportscars_de...id=4024&page=1
and this page:
http://www.3sxperformance.com/exhaust-tt.asp
What confuses me, is that stillen calls it a "race pipe" and 3sx calls it a "down pipe" and then you can buy a "race pipe" to go along with it.
My question is this: If I buy a stillen race pipe, then I don't need a 3sx downpipe correct? Also, I wouldn't need the 3sx race pip either because it looks like the stillen race pipe is the 3sx downpipe + race pipe together.
Am I right? Wrong? Help ?
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 09-06-2004, 11:12 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
The Stillen downpipe is actually a downpipe + a race pipe (aka test pipe). The "race pipe" is a straight through pipe that replaces the catylitic converter. If you were to get the Stillen version, no you would not need a "race pipe," however if you were to buy the 3sx downpipe, you would still need a race pipe.
Below is a picture of the stock downpipe + catylitic converter compared against the Stillen downpipe. As you can see, the Stillen downpipe includes a section that replaces the cat, so you would not need a race pipe.
good luck.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-06-2004, 01:45 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Hrmm sounds like a sweet deal except it'd be harder to swap in the stock one every two years when they test for emissions here in Massachusetts.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 09-06-2004, 04:45 PM
Linebckr49's Avatar
Ya, it might not be quick and easy to swap the stock dp+cat back in, but again, its once every TWO years! i think you wouldn't mind that inconvenience once every 730 days.
93 3000GT base
Old 09-06-2004, 05:47 PM
Thourun's Avatar
Yea I guess, but isn't it hard to attach the downpipe? ..... Ohh wait I'm thinking of headers/exhaust manafolds, the down pipe is easy to bolt on/off right?
1995 3000GT VR-4
Old 09-06-2004, 06:50 PM
Igovert500's Avatar
blue + red light magnet
Re: Help! Confused about 3sx downpipe and stillen race pipe
Yeah, for those long aftermarket downpipes like Stillen and ATR, just cut them down, get a highflow cat and bolt that on. 3sx actually sells them in combos, if you are subject to emissions.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 09-06-2004, 07:05 PM
Gateway's Avatar
I don't have emissions testing, so I think I'll get the stillen race pipe.
'92 3000GT VR4
Current Mods:
K&N FIPK
Rebuilt tranny
Free Boost Mod
Old 09-06-2004, 07:24 PM
Igovert500's Avatar
http://johnmonnin.netfirms.com/Downpipe.html
Read this before making a decision.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
