I've been trying to program my remote locks. The remote works fine to lock the doors, but will not unlock. I need to use the key for unlocking. What am I missing???
Re: door lock remote
Here is a reply to a similar question:
Here is the answer to your question, but it looks like you will have to take it to the dealer since the Fobs have to be programmed with a scan tool. Transmitter Programming Transmitter Programming Important All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. Install a scan tool. Turn ON the ignition, with the engine OFF. Use the scan tool in order to access the Body Control Module (BCM) Special Function: Program Key Fobs. Press the START soft key on the scan tool. Important The scan tool must stay connected until all of the transmitters are programmed. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the locks will cycle in order to confirm the programming of that transmitter. Repeat the previous step in order to program up to 4 transmitters. Remove the scan tool. Operate the transmitter functions in order to verify correct system operation. __________________ John [email protected] 2003 Silverado LS 4.3 Flowmaster 40 Series dual out -- Hypertech Programmer III -- K&N CAI Westin 2" lowering shackels -- Escalade dash bezel -- Coachworks Billet Grille GM Billet Bowtie -- Escalade Inner/Outer chrome door handles |
