Old 09-05-2004, 07:48 PM
evilbeef evilbeef is offline
Ohms
Could someone explain ohms to me like how you know how many ohms everything is. Like this amp i was looking at says:
250x2 @ 4 Ohm Stereo RMS
500x2 @ 2 Ohm Stereo RMS
750x2 @ 1 Ohm Stereo RMS
500x1 @ 4 Ohm Mono RMS
1000x1 @ 2 Ohm Mono RMS
so, how many watts is it?
Old 09-05-2004, 08:16 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Ohms
"ohm" is a measure of resistance or impedance. A voltage is applied across a resistance, and as a result a current flows. A lower resistance will allow more current for a given voltage, and a higher resistance will allow less current for a given voltage. Power is the product of current and voltage, so you can see that a lower resistance will allow more current and you'll get more power. But, the resistance can't be too low or you'll get too much current and the amp will get too hot and pieces will start frying.
Amps are designed to run any speaker down to a certain impedance, in your case, it can run any speaker down to 1ohm if you're using it in stereo (one channel per load), or 2ohm if you're using it bridged (combining both channels to run one load).
All that being said, that amp's specs are insane. Its stereo power ratings don't match up with its bridged power ratings, what amp is it?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-06-2004, 03:01 PM
Its an audiobahn amp i saw on ebay for 200 bones and i though about getting it i have 2 15's that are 1200 watts and my amp now is pussy so i was going to get a better one the whole thing is:
True Digital Full-Range
New for 2004, Audiobahn’s True Digital Full-Range Amplifiers are specially designed for sonic clarity—purity in it’s finest element. Full range and mid/high frequencies are truly met with these powerful compact amplifiers.
Common features:
True Digital Circuitry
Multi-Stranded Power Supply Toroids
Double-Sided Glass Epoxy Circuit Board
THD: 0.05%
S/N Ratio: >100dB
Frequency Response: 10Hz-20kHz(+/- 1dB)
Variable High-Pass/Low-pass Crossover: 50Hz To 250Hz
Variable Bass Boost: 0 - 12dB
Optional Digital Volt Meter (ADM100T)
Throughput RCA Connections
4-way Protection Circuitry: Thermal, Short Circuit, Overload, and DC Offset
Dual Cooling Fans
Cobalt Blue Illumination
Chrome Flame Fan Grille
High Gloss Chrome-Plated Finish
NICKEL-PLATED BLOCK TERMINALS
It measures (HxWxD) 2" x 8 1/2" x 12 7/8"
Re: Ohms
So i would be using one channel to each speaker so how many watts would that be into each speaker?
Old 09-06-2004, 03:05 PM
sr20de4evr's Avatar
Re: Ohms
depends on the impedance of your subs
also, stop looking at audiobahn, if you want a new amp then get a real amp, not a paperweight with chrome.
I don't know what's wrong with the people at audiobahn, they don't know how to rate their amps. Those ratings on that amp make no sense, and I've seen other audiobahn amps that follow the same pattern. I don't know about you but I'm pretty hesitant to buy a product from a company that claims power ratings that aren't even possible.
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-06-2004, 11:33 PM
Well what brand is a "real" amp then
Old 09-06-2004, 11:37 PM
TFFantasy44 TFFantasy44 is offline
Re: Ohms
If your looking for inexpensive (and it looks like you are), go with a HiFonics Brutus amp. Ebay has 'em for $270 or so for a 1500 watt @ 1 ohm.
Old 09-07-2004, 12:01 AM
sr20de4evr's Avatar
Re: Ohms
A real amp is just about anything that doesn't have "50000 watt" written all over the amp, yet when you look at the spec sheet it barely puts out 300rms. In other words, anything that's not audiobahn, sony, lanzar, lightning audio, dual, or any of the other bargain basement amps. Simply, if they sell it in best buy or circuit city, stay far away from it.
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-08-2004, 10:13 AM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Ohms
Originally Posted by evilbeef
[b] i saw on ebay for 200 bones and i though about getting it i have 2 15's that are 1200 watts and my amp now is pussy so i was going to get a better one the whole thing is:
Common features:
THD: 0.05%
S/N Ratio: >100dB
Dual Cooling Fans
Being that you didnt know what an ohm is i will go light on the fact that you are even looking at an audioPAWN anyhting....its like the guy with the kicker amp for 350 and thought hifonics was an off brand... for what you will pay for audiobahn you can get much better
Old 09-08-2004, 10:19 AM
CBFryman's Avatar
Banned
Re: Re: Ohms
amen' to that....but your forgetting pioneer, kicker (some of their stuff is ok", Roadmaster, MTX, BOSS, along with other walmart crap brands... real brands that i have grown to love are Digital Designs, RE (Resonant Engineering), Crystal, and TruTech. JL is good but way over priced...
Old 09-08-2004, 02:49 PM
sr20de4evr's Avatar
Re: Ohms
hehehehe roadmaster and boss, those are classics
there's another walmart brand too but I forgot what it is
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-08-2004, 09:43 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
y'all remember kraco and sparkomatic ? There have been some REALLY cheesy brands over the years
Old 09-08-2004, 10:33 PM
pac4eva5 pac4eva5 is offline
legacy. i know a guy that has EVERYTHING legacy. he claims its the best system. very flashy though...........
Old 09-10-2004, 04:42 AM
Navy I.C.'s Avatar
Navy I.C. Navy I.C. is offline
Re: Ohms
don't laugh too quick, i saw some pics of a chick with jensen everything...
it was a show car, factory sponsored, and hitting real high db's...
THE DARKNESS!!!
an African Soup Bone Production...
Old 09-10-2004, 10:43 AM
CBFryman's Avatar
Banned
Re: Re: Ohms
really? well now im just going ot have to go get me a JC whitney catolog and buy up all thoes $30 subs that handle 500w a $25 componet sets that handle 300w.... right? lmao...
