| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
w00t
well boys, i'm now officially a part of the Z family! picked me up a "beater" 86 n/a 300zx today. approx 159k miles on it, engine runs like new. altho, in light of all this, she needs some work done to her.... second gear isn't happy at all, she grinds if you try and shift into it with the rpm's over 1500, i'm thinking the syncro's are done for, the brake light's on (one on the dash) i'm thinking that's cause the left rear brake is slightly gripping on the rotor, something to do with the e-brake, hood's got a fair dint in it, nothing that won't pop out real easy, tiny bit of rust here and there, but for $922 us i'd say i got a pretty goooood deal, didn't get a key for the t tops, any idea how to get those guys open? need the master key or something? i'm not too sure why i didn't get the master key, but oh well.... any questions or comment, i'll be damn happy to answer
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
Re: w00t
Welcome my brother...
If you do not already know... The Supposed 'Zed Community' is a Death Cult set for Armegedon. Now watch the pretty spinning Z emblem... Watch... Watch... You will drive your car into crowds... You will drive your car into crowds... *random person enters the room* Uhhhh... I mean... Welcome to our wonderful community! Good day now! ![]() -Wes
-2000 PY Acura Integra Type-R #686 - WhoRe -1997 EGP Honda Prelude Type-SH - Daily driver R.I.P Hypsi87:Andy Filson
Well Wes was smoking crack, the other kids were learning math. But thats a seperate issue.
Check your brake fluid level, 9 out of 10 times thats why you'll get a dash light. The grind into 2nd is probably from the previous owner jamming the gears at high rpms. Take it easy on the shifts and it shouldn't be a problem. I had a problem with my E brake in the 240 that sounded familar. The e brake on it used a rachet system with a threaded drum that screwed out to put pressure on the rotor. Somehow the drum had screwed all the way out and was lodged against the rotor. Had to buy a rebuild caliper and a new rotor but it was like 300 bucks total so no big deal.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo ![]() Warning: Objects in mirror aren't as fast as they thought they were. |
Re: w00t
Yea thats it... Crack
![]() *murmors* Drive fast... Into a crowd... -Wes
Re: w00t
thats awesome dude, welcome... but hey all this talk of e brakes reminds me to ask about that..mine has very little tension on it, not ebnough to actually keep the car from rolling, and i just changed the pads so its not that....??? im new to this, so if anyone can help me out on how to adjust it id be much apreciated...thanks
Z32s don't use the rear disc brakes for the e brake. They have a small drum brake inboard of the discs that hold the car in place. Probably the drum brakes need new linings or perhaps its just a simple matter of adjustment.
Heres a FAQ on ebrake adjustment: http://twinturbo.net/ttnetfaq/FAQpages/prknbrake.html
Re: w00t
thanks alot, thats wxactly what i thought, and then some mechanic told me that the ebrake still just used the pads...then i told him to look at the brand new pads as towhich he didnt reply, but thank you, ill look at that
Re: w00t
Second gear issue: I wouldn't worry about it too much, either. My beater Celica does that cuz the synchro is shot...it will even pop out of gear if you let off the gas in second gear...so I hold onto it... Just take it easy on the Nascar style speed shifting.Brake light: Add brake fluid. Little reseviour [sp.] right in front of the firewall on the driver's side. When you add it, see if you notice it coming out anywhere...I had a leaking caliper on my old 300 and didn't notice it until I noticed my rim looked wet...it was brake fluid. FYI...brake fluid cleans rims up VERY well. You don't need a key to get the T-tops out unless someone locked it. You could probably get a replacement key from courtesy nissan if it is in fact locked, but I've never looked. You just have to push the little sliding thing up and pull on the handle. If it won't budge, it's probably locked. First few times taking them in or out is pretty tricky...I've gotten to the point where I can take them out sitting at a stop light without taking my seat belt off...
Who cares what's in your wallet...what's in your garage? ![]() VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31 Hope you can see the tiny pic...AF reduced the size limit! Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Re: w00t
brake light went off.... but i gots a story for y'all!!! gather round!
uh yeah anyway.... ok, so the drivers side doesn't lock... no big deal, every time you open the door after driving for a while or attempting to lock it the alarm goes off, i'll get it fixed when i get the car back to k-town and i have a nice warm garage to work in, Anyway... important part of the story, so i'm moving the car from round back to up front of the grandparents house, so i get up, park the car, open the door, alarm goes off... whatever, hurredly get out, go to *unlock* the door which disarms it stick the key in, or so i thought... go to turn it, and come away with the end of the key in my hand, about a third of the other key sitting in the lock... so i run swearing into the house to grab a tool to pull the rest of the key out, pull it out, wait however many min. till the alarm stops going off, call a locksmith... locksmith makes a few keys and goes away.... it was awesome only having one key for the car... don't have the master key anymore, the previous owner musta lost it somewhere or still has it.. (got the car from an auction so they're unable to give us the name of the seller according to some privacy act) anyway, i just hope i can make the 8 hour drive home without pulling a broke as ****.... is there any quick easy fix to unbind that left rear brake? smells pretty funny after driving a while, needs new brake rotors, or maybe just to turn these ones. nother funny story concerning the transmission issue.... anyway, my dad goes to take it for a drive and i forgot to tell him to take it easy going into second.... anyway, as i see him driving away, i remember i forgot to tell him about it, so just as i hear the gas let off, i hear this really loud KKKKKKKKKKTTTTTTTTT..."summbitch!!!" i had to have a laugh oh, and i added some brake fluid, light went off like you guys said, thx
Re: Re: w00t
You mean the driver's door doesn't UNlock? If it didn't lock, the alarm would never get activated to begin with. Even if it didn't lock, I don't think the alarm would go off every time you open the door until the end of time. Sounds a little odd. LOL.......you said "sumbitch"........and *I* live in Kenfucky....lol...
Re: Re: w00t
HEY YOU KNOW WHAT! SCREW YOU! Anyway sounds like the worst that can happen is you have to get a caliper and rotor for the affected corner. Not that bad. If it smells like burnt brakes then thats probably the issue.
Re: w00t
no no, it's permanently UNlocked for the time being, so it won't lock
alright what i think is going on with the lock is, it's going just far enough to hit the "locked" arming switch for the alarm, but not actually locking, like there's a piece of something broken off in there preventing the rod from going all the way and enguaging(sp?) the lock yeeeees llz, those are called dummy locks! they help dummies like you to not lock the keys in your car just playin man ![]() any idea what i could do to fix the transmission... second gear is kind of important.... you know, if i ever wanna... go fast off the line
Look around, you can probably get a rebuilt trans for a couple hundred bucks. Alot easier then getting yours rebuilt (which is what it needs). Alot cheaper too.
Re: w00t
what sorta transmissions would bolt up to my beast, would it have to be a z31 n/a tranny? or could it be say... z32 n/a....
as for getting my tranny rebuilt, why would it be more difficult than finding a new one.... where i live, there aren't many salvage yards, nor 300zx's, taking it to nissan would cost an arm and a leg, so i'm thinking a reputable transmission shop? on a side note, i ordered a catalogue from victoria british about a week ago, hopefully it'll have arrived by now... i doubt they'd have anything in there transmission wise eh?
Re: w00t
Congrats, Delerious! Welcome to the cul-... err... family! Post pix soon!
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105 |
