Old 09-05-2004, 07:18 PM
antmang antmang is offline
Exclamation 91 Honda CRX HF ALternator trouble or ECU?
I have a 91 CRX HF My alternator died a month ago so
I replaced it. Since then my battery light would flash
intermittently and for no apparent reason. This would
only happen once every 60 miles or so. I figured it
had a bad voltage regulator so I replaced it again.
Very shortly after putting in #2 alternator I turn on
my lights and they burnt out... then my highs (since I
was driving at night) and they burnt out too. I had #2
checked and it was occasionally putting out 18 VDC. I
am now getting ready to install my 3rd alternator. My
question is....is there a second voltage regulator in
the ECU that askes for a voltage? If so where is the
ECU located? Under the hood or dash? Could my problem
be a short? None of my fuses have blown. Also when the
voltage first spiked with new #2 I smelled something
funny in the car... I'm not sure if it was the fresh
oil change (spill) or it toasted something under the
dash. Any help would be appreciated. If you think it
would be easier for me to call please give me your
number. Thanks Anthony [email protected]
Old 09-05-2004, 11:11 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: 91 Honda CRX HF ALternator trouble or ECU?
You'll see your ecu under your carpet on the passenger side. Sounds like you need to check your ground wire? Its kinda hard to tell , i would have to see it.
