Old 09-05-2004, 05:20 PM
wildstringer's Avatar
wildstringer wildstringer is offline
mass air flow computer
im not sure if there has been a thread for this or not . anyway, I was wondering if anyone knows if a computer out of a 90 cougar with a 5.0 would work for my 87 5.0 for use in a mass air flow conversion.i m not sure what the number on the computer is . i just saw a few of them in a junk yard today . any info would be greatly appreciated
Old 09-05-2004, 05:32 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
do your research, make sure the computer numbers match up. most likely, they won't.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 09-05-2004, 07:19 PM
well i thought that this was a place to help each other out with questions . so i thought if someone might know it would save me a bunch of time in searching for all the possible numbers. so if you dont know the answer to my question ,Stangnut,then why the hell did you reply .
Old 09-05-2004, 07:59 PM
well, if you would think about what i wrote, you wouldn't be all mad. i said, most likely the numbers won't match up. i said this because i know that they altered the computers from year to year, but i dont' know anything about cougar computers or how they relate to mustang computers. if i were you i'd buy a service manual for your car and compare it to that for your potential donor car. you'll be able to find the specific numbers you're looking for. unless, of course, somebody on here happens to know exactly what you need, which is unlikely.
-Andy
Old 09-05-2004, 10:20 PM
hey look man reguardless what you said i shouldnt have been like that . i apologize . I was pissed off cause someone busted my window today. thats why i was at the junkyard in the first place. i took my frustrations out on you . just cant stand people who wont let you have something nice .sorry . maybe i ll buy a cougar manual to cross the #'s.
Old 09-05-2004, 10:24 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: mass air flow computer
The computer you want is an A9L. Typically found in '89-93 5.0 Mustangs. Check junkyards and E-bay for the best deals...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 09-05-2004, 10:33 PM
i have seen that A9L on ebay quite a few times thanks.by the way does auto or 5 spd make a diff?
Old 09-06-2004, 03:33 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Yes, I believe it has to do with idle control but I could be wrong. The A9L is the manual computer and the A9P is the auto computer. However oddball computers were used now and then and the Cobra computers are different too.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 09-06-2004, 05:09 PM
Yeah, but Cobra comp's were also designed for 24 lb injectors, if you wanna keep it cheap, A9L/A9P depending on tranny..
Freedom Isn't Free.
Old 09-07-2004, 04:10 PM
burly94gt burly94gt is offline
jeez... everyone has been so touchy lately. 3 out of the past 5 threads have lead to a rediculous agrument about almost nothing. lets all take a deeeeep breath and count to ten. hah we are all here for the same reason, so just, take it easy
have a great day
God said RWD, and all the little torque lovers of the world said, AMEN!!
Old 09-08-2004, 08:50 AM
Re: Re: mass air flow computer
thats the thing i plan on going to 24lb with a 70 mm mass air just want sure if it would be cheaper to buy it all separate or just get the kit. of course i d feel better about a new computer vs an old one but my head might not feel better when my wife beats on it for spending 650.00 on the kit i found
Old 09-08-2004, 05:10 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
jegs has the same kit with 70mm mass air meter, 24lb injectors,and matching computer for $545.99 its not a whole lot less but every penny counts on a tight budget. (aka wife) i have the same problem with the g/f...
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 09-08-2004, 11:32 PM
no thats not bad i know summit had a kit but was for stock 19lb but it didnt come with new injectors of course. thanks alot i ll give them a call
Old 09-09-2004, 09:58 PM
I checked with jegs but it seems that this more of an upgrade kit than a conversion kit .they are telling me i need to convert it first then go with the larger injectors and maf. maybe i'll just buy a new computer and find the instructions online somewhere for the conversion.
Old 09-10-2004, 12:29 PM
The problem you will run into with a Cobra computer is when you do swap either MAF's or injectors in the future, it creates complications, because the MAF will have to be cal'ed for the Cobra comp.
I say get a Pro-M MAF and rip the harness and computer out of a JY.
Freedom Isn't Free.
