Old 09-05-2004, 04:03 PM
90talon 90talon is offline
my car missfires when cold and wont rev past 3500 rpms
when my car is cold it breaks up at like 2500-3500 rpms and wont go past that and it sounds like its hitting a rev limiter but then after driving it for a half hour or so it gets better and but breaks up at 4500 rpms and takes a second to rev out
Old 09-05-2004, 04:34 PM
96TSi's Avatar
96TSi 96TSi is offline
Send a message via AIM to 96TSi
Re: my car missfires when cold and wont rev past 3500 rpms
hmm.. my 1g did something similar to that when i had a boost problem.
04 SRT-4
03 Evo
96 Talon TSi AWD *dead*
93 Talon TSi AWD *sold*
85 300ZX Turbo
90 300zx Twin Turbo
82 Karen
04 little boy
Old 09-06-2004, 12:02 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
sounds like the fuel filter is plugged or a fuel problem not boost problems... if it were boost problems they would get worse as the engine heated up. are your plugs gapped correctly? check engine light on?
Old 09-10-2004, 01:07 PM
yeah my plugs are ok but i just recently took my ecu out and took the cover off and it smelled really like burt i guess yu can say, so i took the other four screws off and needless to say i found burn marks on the bottom and some of the soldered pieces were burt to so im assuming thats my prob
thanx for all your help
Old 09-10-2004, 01:11 PM
oh yeah my oil pressure is unusually high at idle and while driving its in the middle of the lines at idle
any ideas of what it could be
Old 09-10-2004, 01:46 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I don't have personal experience with this, but I have heard guys talking about leaking caps on the ECU board. My understanding is that you need to remove the old caps and replace them.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-10-2004, 03:07 PM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
if its leaking capacitors you should be able get some new ones at... radio shack maybe? if thats the case tho yeah some soldering and your in bizness but if the board is burnt up that might need some work too.. i wonder if it aint worth it to invest in a new or used ecu
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
